Datasheet G5SB-14 12DC - Omron Даташит Реле, PCB, 12 В DC — Даташит
Наименование модели: G5SB-14 12DC
![]() 22 предложений от 13 поставщиков Реле, Конфиг: 1C, Uкатушки: 12 В, DC, Мощность катушки (max): 400 мВт, контакты: 5 А, UDC: 30 В | |||
G5SB-14-12DC Omron | 117 ₽ | ||
G5SB1412DC Omron | 132 ₽ | ||
G5SB1412DC Omron | 513 664 ₽ | ||
G5SB-14-12DC Omron | по запросу |
Производитель: Omron
Описание: Реле, PCB, 12 В DC
PCB Relay
G5SB
Compact Single-pole Relay for Switching 5 A (Normally Open Contact), Fan Control of Air Conditioners, and Heating Control of Small Appliances.
· Environment-friendly, Pb-free.
· Compact SPDT Relay with high insulation. · Incorporates a normally open contact that switches 5 A max. · Ensures a withstand impulse voltage of 8,000 V between the coil and contacts. · Conforms to UL and CSA.
· UL508 · CSA C22.2 (No.14) · VDE approval is in progress. Note: The G5S-1 will be discontinued at the end of March 2004. Please change to the G5SB (Environment-friendly Relay).
- Тип реле: Power
- Coil Voltage VDC Nom: 12 В
- Contact Current Max: 5 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 360 Ом
- Contact Configuration: SPDT
- Coil Type: DC Coil
- Coil Current: 33.3 мА
- Nom Operating Power: 400 мВт
- Relay Mounting: PC Board
- Внешняя длина / высота: 15.8 мм
- Внешняя ширина: 20.3 мм
- External Depth: 10.3 мм
- Contact Current AC Max: 5 А
- Contact Current DC Max: 5 А
- Contact Voltage AC Max: 250 В
- Contact Voltage DC Max: 30 В
- Mounting Type: PCB
- No. of Poles: 1
- Operating Temperature Max: 70°C
- Series: G5SB
- Temperature Operating Min: -40°C
- Approval Bodies: CSA
- Approval Category: UL Recognised
- Contact Current Min: 10 мА
- Contact Current Rating: 3 А
- Contact Material: Ag alloy
- Contact Resistance: 100 MOhm
- Current Rating: 33.3 мА
- DC Coil Power: 400 мВт
- Dielectric Voltage Coil to Contact: 4000 В AC
- Dielectric Voltage Contact to Contact: 1000 В AC
- Insulation Resistance: 1000 MOhm
- Mechanical Life: 5,000,000 operations
G5SB14 12DC, G5SB 14 12DC
