Datasheet G5SB-14 5DC - Omron Даташит Реле, PCB, 5 В DC — Даташит
Omron G5SB-14 5DC
Наименование модели: G5SB-14 5DC
Промышленные/Универсальные Реле, Electromechanical Relay SPDT 5(NO)/3(NC)A 5VDC 63Ω Through Hole
G5SB145DC
Omron
127 ₽
G5SB145DC
Omron
183 ₽
TradeElectronics
G5SB145DC
Omron
G5SB145DC
Yageo
Производитель: Omron
Описание: Реле, PCB, 5 В DC
data sheetСкачать Data Sheet
PCB Relay
G5SB
Compact Single-pole Relay for Switching 5 A (Normally Open Contact), Fan Control of Air Conditioners, and Heating Control of Small Appliances.
· Environment-friendly, Pb-free.
· Compact SPDT Relay with high insulation. · Incorporates a normally open contact that switches 5 A max. · Ensures a withstand impulse voltage of 8,000 V between the coil and contacts. · Conforms to UL and CSA.
· UL508 · CSA C22.2 (No.14) · VDE approval is in progress. Note: The G5S-1 will be discontinued at the end of March 2004. Please change to the G5SB (Environment-friendly Relay).
  • Тип реле: Power
  • Coil Voltage VDC Nom: 5 В
  • Contact Current Max: 5 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 63 Ом
  • Contact Configuration: SPDT
  • Coil Type: DC Coil
  • Coil Current: 80 мА
  • Nom Operating Power: 400 мВт
  • Relay Mounting: PC Board
  • Внешняя длина / высота: 15.8 мм
  • Внешняя ширина: 20.3 мм
  • External Depth: 10.3 мм
  • Contact Current AC Max: 5 А
  • Contact Current DC Max: 5 А
  • Contact Voltage AC Max: 250 В
  • Contact Voltage DC Max: 30 В
  • Mounting Type: PCB
  • No. of Poles: 1
  • Operating Temperature Max: 70°C
  • Series: G5SB
  • Temperature Operating Min: -40°C
  • Approval Bodies: CSA
  • Approval Category: UL Recognised
  • Contact Current Min: 10 мА
  • Contact Current Rating: 3 А
  • Contact Material: Ag alloy
  • Contact Resistance: 100 MOhm
  • Current Rating: 80 мА
  • DC Coil Power: 400 мВт
  • Dielectric Voltage Coil to Contact: 4000 В AC
  • Dielectric Voltage Contact to Contact: 1000 В AC
  • Insulation Resistance: 1000 MOhm
  • Mechanical Life: 5,000,000 operations
G5SB14 5DC, G5SB 14 5DC
На английском языке: Datasheet G5SB-14 5DC - Omron RELAY, PCB, 5 V DC
