Datasheet G6CK-2117P-US 12DC - Omron Даташит Реле, PCB, SPNO & SPNC, 12 В DC — Даташит
Наименование модели: G6CK-2117P-US 12DC
G6CK2117PUS12DC Omron | 542 ₽ | ||
G6CK2117PUS12DC Omron | 654 ₽ |
Производитель: Omron
Описание: Реле, PCB, SPNO & SPNC, 12 В DC
PCB Relay
SPST-NO Type Breaks 10-A Loads; SPST-NO + SPST-NC Type Breaks 8-A Load
G6C
Compact: 20 Ч 15 Ч 10 mm (L Ч W Ч H).
Low power consumption: 200 mW. Flux protection or fully sealed construction available. Unique moving loop armature reduces relay size, magnetic interference, and contact bounce. Single- and double-winding latching types also available RoHS Compliant
Refer to pages 16 to 17 for details.
- Тип реле: Power
- Coil Voltage VDC Nom: 12 В
- Contact Current Max: 8 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 514 Ом
- Contact Configuration: SPNO / SPNC
- Coil Type: DC Coil
- Coil Current: 23.3 мА
- Nom Operating Power: 280 мВт
- Relay Mounting: PC Board
- Внешняя длина / высота: 10 мм
- Внешняя ширина: 20 мм
- External Depth: 15 мм
- Contact Current AC Max: 8 А
- Contact Current DC Max: 8 А
- Contact Voltage AC Max: 250 В
- Contact Voltage DC Max: 30 В
- Mounting Type: PCB
- No. of Poles: 1
- Series: G6C
- Temperature Operating Min: 70°C
- Type: Double Winding - Latching
- Approval Bodies: CSA, VDE, SEV and TUV
- Approval Category: UL Recognised
- Coil Operating Lower Percent Limit: 70%
- Coil Operating Upper Percent Limit: 70%
- Contact Material: Ag Alloy
- Contact Resistance: 30 MOhm
- Current Rating: 8 А
- DC Coil Power: 280 мВт
- Dielectric Strength VAC: 2000 В AC
- Dielectric Voltage Coil to Contact: 2000 В AC
- Dielectric Voltage Contact to Contact: 1000 В AC
- Insulation Resistance: 1000 MOhm
Дополнительные аксессуары:
- Omron - P6B-C2
G6CK2117PUS 12DC, G6CK 2117P US 12DC
