Datasheet G6DS-1A 5DC - Omron Даташит Реле, PCB, SPNO, 5 В DC — Даташит
Наименование модели: G6DS-1A 5DC
![]() Реле Мощности, Electromechanical Relay SPST-NO 5A 5VDC 139Ω Through Hole | |||
G6DS1A5DC Omron | 330 ₽ | ||
G6DS1A5DC Omron | 346 ₽ | ||
G6DS1A5DC Omron | 389 ₽ |
Производитель: Omron
Описание: Реле, PCB, SPNO, 5 В DC
PCB Power Relay G6DS
Power Relays
Enclosure ratings Fully sealed G6DS-1A G6DS-1A-H Model 3.
Classification None: Standard H: High-sensitivity 4. Rated Coil Voltage 5, 12, 24 VDC
Slim, Miniature Relay with 1-pole 5-A Switching Capability
RoHS compliant. Slim 5-mm width and miniature size.
- Тип реле: Power
- Coil Voltage VDC Nom: 5 В
- Contact Current Max: 5 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 139 Ом
- Contact Configuration: SPST
- Coil Type: DC Coil
- Coil Current: 36 мА
- Nom Operating Power: 180 мВт
- Relay Mounting: PC Board
- Внешняя длина / высота: 12.5 мм
- Внешняя ширина: 20.3 мм
- External Depth: 5.08 мм
- Contact Current AC Max: 5 А
- Contact Current DC Max: 5 А
- Contact Voltage AC Max: 250 В
- Contact Voltage DC Max: 30 В
- Mounting Type: PCB
- No. of Poles: 1
- Operating Temperature Max: 85°C
- Series: G6DS
- Temperature Operating Min: -40°C
- Approval Bodies: CSA, VDE
- Approval Category: UL Recognised
- Coil Operating Lower Percent Limit: 5%
- Coil Operating Upper Percent Limit: 70%
- Contact Material: AgNi
- Contact Resistance: 100 MOhm
- DC Coil Power: 180 мВт
- Dielectric Voltage Coil to Contact: 3000 В AC
- Dielectric Voltage Contact to Contact: 750 В AC
- Insulation Resistance: 1000 MOhm
- No. of Electrical Operations: 100000
G6DS1A 5DC, G6DS 1A 5DC
