Datasheet G6J-2P-Y-DC5 - Omron Даташит PCB Реле, CONTACTS DPDT — Даташит
Наименование модели: G6J-2P-Y-DC5
![]() 13 предложений от 10 поставщиков Промышленные/Универсальные Реле, Electromechanical Relay DPDT 1A 5VDC 173.1Ω Through Hole | |||
G6J-2P-Y-DC5 Omron | 202 ₽ | ||
G6J2PYDC5 Omron | 276 ₽ | ||
G6J-2P-Y-DC5 Omron | от 580 ₽ | ||
G6J-2P-Y-DC5V Omron | по запросу |
Производитель: Omron
Описание: PCB Реле, CONTACTS DPDT
low power consumption and spacesaving size.
The fail-safe model requires just 700mW, whilst the latching version saves even more power because it requires only a set or reset pulse to change operating state. Small size, low power consumption... The G6Z, G6Y and G6W 10W RF relays all use microstrip technology to achieve small size and low power consumption combined with excellent RF performance. All three have low power consumption of 200mW feature good isolation characteristics. At 1GHz, the isolation for the G6Y is 60dB. At 2.5GHz, the isolation for the G6Z is 45dB(Y-TH) and the G6W is 60dB.
Omron Electronic Components Europe B.V. Sales Division France 14, rue de Lisbonne 93561 Rosny Sous Bois France Tel: +33 1 56 63 19 00 Fax: +33 1 48 55 97 75 Omron Electronic Components Europe B.V. Sales Division Central Europe Gruber Strasse 60d 85586 Poing Germany Tel: +49 8121 77240 Fax: +49 8121 772440 Omron Electronic Components Europe B.V. Sales Division Italy Viale Certosa 49 20149 Milano I
- Coil Voltage VDC Nom: 5 В
- Coil Resistance: 173.1 Ом
- Contact Configuration: DPDT
- Внешняя длина / высота: 9 мм
- Внешняя ширина: 10.6 мм
- External Depth: 5.7 мм
- Contact Current AC Max: 300 мА
- Contact Current DC Max: 1 А
- Contact Voltage AC Max: 125 В
- Contact Voltage DC Max: 30 В
- Mounting Type: PCB
- No. of Poles: 2
- Series: G6J-Y
G6J2PYDC5, G6J 2P Y DC5
