Datasheet G6RL-1A 24DC - Omron Даташит Реле, PCB, SPST, 24 В DC — Даташит
Omron G6RL-1A 24DC
Наименование модели: G6RL-1A 24DC
Реле, модуль Ввода/Вывода, Electromechanical Relay SPST-NO 10A 24VDC 2.618KΩ Through Hole
G6RL1A24DC
Omron
81 ₽
G6RL1A24DC
Omron
155 ₽
G6RL1A24DC
Omron
172 ₽
T-electron
G6RL1A24DC
11 165 ₽
Производитель: Omron
Описание: Реле, PCB, SPST, 24 В DC
data sheetСкачать Data Sheet
PCB Relay
Low-profile power relay with maximum switching of 10 A
Low profile: 12.3 mm in height Max.
switching capacity: 2,500 VA (NO) Dielectric strength: 5 kV Clearance and creepage distance: 10 mm.
G6RL
RoHS Compliant
  • Тип реле: Power
  • Coil Voltage VDC Nom: 24 В
  • Contact Current Max: 10 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 24 В
  • Coil Resistance: 2.618 кОм
  • Contact Configuration: SPST
  • Coil Type: DC Coil
  • Coil Current: 9.2 мА
  • Nom Operating Power: 220 мВт
  • Relay Mounting: PC Board
  • Внешняя длина / высота: 12.3 мм
  • Внешняя ширина: 28.5 мм
  • External Depth: 10 мм
  • Contact Current AC Max: 10 А
  • Contact Current DC Max: 5 А
  • Contact Voltage AC Max: 400 В
  • Contact Voltage DC Max: 300 В
  • Mounting Type: PCB
  • No. of Poles: 1
  • Operating Temperature Max: 85°C
  • Series: G6RL
  • Temperature Operating Min: -40°C
  • Approval Bodies: VDE
  • Approval Category: UL Recognised
  • Coil Operating Lower Percent Limit: 10%
  • Coil Operating Upper Percent Limit: 70%
  • Contact Material: AgNi
  • Contact Resistance: 100 MOhm
  • DC Coil Power: 220 мВт
  • Dielectric Voltage Coil to Contact: 5000 В AC
  • Dielectric Voltage Contact to Contact: 1000 В AC
  • Flammability Rating: UL94V-0
  • Insulation Resistance: 1000 MOhm
  • Insulation Resistance Voltage: 500 В DC
G6RL1A 24DC, G6RL 1A 24DC
На английском языке: Datasheet G6RL-1A 24DC - Omron RELAY, PCB, SPST, 24 V DC
