Datasheet G6RN-1 5DC - Omron Даташит Реле, PCB, SPCO, 5 В DC — Даташит
Наименование модели: G6RN-1 5DC
![]() 31 предложений от 14 поставщиков Промышленные/Универсальные Реле, Electromechanical Relay SPDT 5ADC/8AAC 5VDC 114Ω Through Hole | |||
G6RN15DC Omron | 68 ₽ | ||
G6RN15DC Omron | от 120 ₽ | ||
G6RN15DC Omron | 148 ₽ | ||
G6RN-1-5DC Omron | по запросу |
Производитель: Omron
Описание: Реле, PCB, SPCO, 5 В DC
PCB Relay
Heavy-duty Miniature Relay
I I I I I I I
G6RN
Incorporates environment-friendly, cadmium-free contacts.
Variety of contact forms: SPDT or SPST-NO (continuous current rating: 8 A) Mechanical and electrical characteristics comply with VDE0435. Satisfies VDE0700 requirements with a dielectric strength of 4 kV at a distance of 8 mm. Satisfies C/250 insulation requirements of VDE0110. Tracking resistance: CTI>250 Conforms to class II, part 1 of VDE0106.
- Тип реле: Power
- Coil Voltage VDC Nom: 5 В
- Contact Current Max: 8 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 114 Ом
- Contact Configuration: SPCO
- Coil Type: DC Coil
- Coil Current: 44 мА
- Nom Operating Power: 220 мВт
- Relay Mounting: PC Board
- Внешняя длина / высота: 15.3 мм
- Внешняя ширина: 28.8 мм
- External Depth: 10.5 мм
- Contact Current AC Max: 8 А
- Contact Current DC Max: 5 А
- Contact Voltage AC Max: 240 В
- Contact Voltage DC Max: 30 В
- Mounting Type: PCB
- No. of Poles: 1
- Operating Temperature Max: 85°C
- Series: G6RN
- Temperature Operating Min: -40°C
- Approval Bodies: CSA and VDE
- Approval Category: UL Recognised
- Coil Operating Lower Percent Limit: 70%
- Coil Operating Upper Percent Limit: 110%
- Contact Material: AgNi
- Contact Plating: Gold
- DC Coil Power: 220 мВт
- Operating Time: 15 мс
- Release Time: 5 мс
- Switch Current Max: 8 А
- Switching Power Max: 2000VA
- Вес: 9 г
Дополнительные аксессуары:
- Omron - G6RL-1 5DC
G6RN1 5DC, G6RN 1 5DC
