Datasheet G6S-2G DC12 - Omron Даташит Реле, DPDT 12 В DC — Даташит
Omron G6S-2G DC12
Наименование модели: G6S-2G DC12
12 предложений от 9 поставщиков
Реле слабых сигналов - для печатного монтажа InsideL NonLatch 2A DPDT 12DC 140mW
G6S-2GDC12 BY OMR
Omron
168 ₽
Элитан
G6S2GDC12
Omron
395 ₽
G6S-2G-DC12
G6S-2GDC12BYOMBR-C
Omron
Производитель: Omron
Описание: Реле, DPDT 12 В DC
data sheetСкачать Data Sheet
PCB Relay
Surface Mounting DPDT Relay
G6S
Long terminals for ideal for soldering and mounting reliability.
Space-saving inside-L terminal. High dielectric strength between coil and contacts (2,000 VAC), and between contacts of different polarity (1,500 VAC). High impulse withstand voltages between coil and contacts, and between contacts of different polarity (2,500 V, 2 Ч 10 µs: Bellcore requirements). Low power consumption (140 mW). Bifurcated crossbar contact (Au-clad) and Fully sealed construction for high reliability. Applicable to IRS. High sealability after IRS. Ultra-miniature at 15 Ч 7.5 Ч 9.4 mm (L Ч W Ч H). Through-hole terminal is available EN60950/EN41003 Supplementary Insulationcertified type is available. RoHS Compliant
Refer to pages 16 to 17 for details.
  • Тип реле: Power
  • Coil Voltage VDC Nom: 12 В
  • Contact Current Max: 2 А
  • Contact Voltage AC Nom: 125 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 1.028 кОм
  • Contact Configuration: DPDT
  • Coil Type: DC Coil, Monostable
  • Coil Current: 11.7 мА
  • Nom Operating Power: 140 мВт
  • Relay Mounting: PC Board
  • Внешняя длина / высота: 9.2 мм
  • Внешняя ширина: 14.8 мм
  • External Depth: 7.3 мм
  • Contact Current AC Max: 500 мА
  • Contact Current DC Max: 2 А
  • Contact Voltage AC Max: 125 В
  • Contact Voltage DC Max: 30 В
  • Mounting Type: SMT
  • No. of Poles: 2
  • Operating Temperature Max: 85°C
  • Series: G6S
  • Temperature Operating Min: -40°C
  • Termination Type: SMD
  • Type: Single-side stable
  • Approval Bodies: CSA
  • Approval Category: UL Recognised
  • Contact Current Min: 10ВµA
  • Contact Material: Ag
  • Contact Plating: Au
  • Contact Resistance: 75 MOhm
  • DC Coil Power: 140 мВт
  • Dielectric Voltage Coil to Contact: 2000 В AC
  • Dielectric Voltage Contact to Contact: 1000 В AC
  • Insulation Resistance: 1000 MOhm
Дополнительные аксессуары:
  • COOPER TOOLS / WELLER - SD1000
G6S2G DC12, G6S 2G DC12
На английском языке: Datasheet G6S-2G DC12 - Omron RELAY, DPDT 12 V DC
