Datasheet G6SU-2 DC3 - Omron Даташит Реле, DPDT, 3 В DC — Даташит
Наименование модели: G6SU-2 DC3
![]() 13 предложений от 10 поставщиков Промышленные/Универсальные Реле, OMRON ELECTRONIC COMPONENTS G6SU-2DC3 BY OMR Signal Relay, DPDT, 3VDC, 2A, G6S Series, Through Hole, Latching Single Coil | |||
G6SU2DC3BYOMR Omron | 222 ₽ | ||
G6SU2DC3BYOMZ Omron | 236 ₽ | ||
G6SU-2-DC3V Omron | по запросу | ||
G6SU-2-DC3 | по запросу |
Производитель: Omron
Описание: Реле, DPDT, 3 В DC
PCB Relay
Surface Mounting DPDT Relay
G6S
Long terminals for ideal for soldering and mounting reliability.
Space-saving inside-L terminal. High dielectric strength between coil and contacts (2,000 VAC), and between contacts of different polarity (1,500 VAC). High impulse withstand voltages between coil and contacts, and between contacts of different polarity (2,500 V, 2 Ч 10 µs: Bellcore requirements). Low power consumption (140 mW). Bifurcated crossbar contact (Au-clad) and Fully sealed construction for high reliability. Applicable to IRS. High sealability after IRS. Ultra-miniature at 15 Ч 7.5 Ч 9.4 mm (L Ч W Ч H). Through-hole terminal is available EN60950/EN41003 Supplementary Insulationcertified type is available. RoHS Compliant
Refer to pages 16 to 17 for details.
- Тип реле: Power
- Coil Voltage VDC Nom: 3 В
- Contact Current Max: 2 А
- Contact Voltage AC Nom: 125 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 90 Ом
- Contact Configuration: DPDT
- Coil Type: DC Coil
- Coil Current: 33.3 мА
- Nom Operating Power: 100 мВт
- Relay Mounting: PC Board
- Внешняя длина / высота: 9.2 мм
- Внешняя ширина: 14.8 мм
- External Depth: 7.3 мм
- Contact Current AC Max: 500 мА
- Contact Current DC Max: 2 А
- Contact Voltage AC Max: 125 В
- Contact Voltage DC Max: 30 В
- Mounting Type: PCB
- No. of Poles: 2
- Operating Temperature Max: 85°C
- Series: G6S
- Temperature Operating Min: -40°C
- Type: Single coil latching
- Approval Bodies: CSA
- Approval Category: UL Recognised
- Contact Current Min: 10ВµA
- Contact Material: Ag
- Contact Plating: Au
- Contact Resistance: 75 MOhm
- DC Coil Power: 100mW
- Dielectric Voltage Coil to Contact
- Dielectric Voltage Contact to Contact: 1000 В AC
- Insulation Resistance: 1000 MOhm
- Insulation Resistance Voltage: 500 В DC
Дополнительные аксессуары:
- COOPER TOOLS / WELLER - SD1000
G6SU2 DC3, G6SU 2 DC3
