Datasheet G7L-2A-T 100/120VAC - Omron Даташит Реле, DPNO, 25 А, 120VAC — Даташит
Omron G7L-2A-T 100/120VAC
Наименование модели: G7L-2A-T 100/120VAC
Элитан
G7L-2A-T-100/120VAC
Omron
3 279 ₽
Производитель: Omron
Описание: Реле, DPNO, 25 А, 120VAC
data sheetСкачать Data Sheet
Power Relay
A High-capacity, High-dielectric-strength Relay Compatible with Momentary Voltage Drops
No contact chattering for momentary voltage drops up to 50% of rated voltage.
Wide-range AC-activated coil that handles 100 to 120 or 200 to 240 VAC at either 50 or 60 Hz. Miniature hinge for maximum switching power, particularly for inductive loads. Flame-resistance materials (UL94V-0-qualifying) used for all insulation material. Quick-connect, screw, and PCB terminals, and DIN track mounting available.
G7L
RCE
  • Тип реле: General Purpose
  • Coil Voltage VAC Nom: 120 В
  • Contact Current Max: 25 А
  • Contact Voltage AC Nom: 220 В
  • Contact Configuration: DPNO
  • Coil Type: AC Coil
  • Coil Current: 20.4 мА
  • Nom Operating Power: 2.5VA
  • Relay Mounting: Bracket
  • Внешняя длина / высота: 52.5 мм
  • Внешняя ширина: 33.5 мм
  • External Depth: 47 мм
  • Contact Current AC Max: 25 А
  • Contact Voltage AC Max: 220 В
  • Mounting Type: Bracket
  • No. of Poles: 2
  • Operating Temperature Max: 60°C
  • Series: G7L
  • Temperature Operating Min: -25°C
  • AC Coil Power: 2.5VA
  • Approval Bodies: UL, CSA, VDE, IEC
  • Coil Operating Lower Percent Limit: 75%
  • Coil Operating Upper Percent Limit: 110%
  • Coil Voltage Max: 120 В AC
  • Coil Voltage Min: 100 В AC
  • Switch Current Max: 20 А
  • Switching Power Max: 5500VA
  • Terminal Type: 6.35 мм x 0.8 мм
G7L2AT 100/120VAC, G7L 2A T 100/120VAC
На английском языке: Datasheet G7L-2A-T 100/120VAC - Omron RELAY, DPNO, 25 A, 120VAC
