Datasheet G7L-2A-T 200/240AC - Omron Даташит Реле, DPNO, 25 А, 240VAC — Даташит
Наименование модели: G7L-2A-T 200/240AC
Купить G7L-2A-T 200/240AC на РадиоЛоцман.Цены — от 646 до 161 967 ₽ 6 предложений от 6 поставщиков INDUSTRIAL RELAY 200/240V 25A ** | |||
G7L2AT200240AC Omron | 646 ₽ | ||
G7L2AT200240AC Omron | 672 ₽ | ||
G7L2AT200240AC Omron | 689 ₽ | ||
G7L2AT200240AC | 161 967 ₽ |
Производитель: Omron
Описание: Реле, DPNO, 25 А, 240VAC
Power Relay
A High-capacity, High-dielectric-strength Relay Compatible with Momentary Voltage Drops
No contact chattering for momentary voltage drops up to 50% of rated voltage.
Wide-range AC-activated coil that handles 100 to 120 or 200 to 240 VAC at either 50 or 60 Hz. Miniature hinge for maximum switching power, particularly for inductive loads. Flame-resistance materials (UL94V-0-qualifying) used for all insulation material. Quick-connect, screw, and PCB terminals, and DIN track mounting available.
G7L
RCE
- Тип реле: General Purpose
- Coil Voltage VAC Nom: 240 В
- Contact Current Max: 25 А
- Contact Voltage AC Nom: 220 В
- Contact Configuration: DPNO
- Coil Type: AC Coil
- Coil Current: 10.2 мА
- Nom Operating Power: 2.5VA
- Relay Mounting: Bracket
- Внешняя длина / высота: 52.5 мм
- Внешняя ширина: 33.5 мм
- External Depth: 47 мм
- Contact Current AC Max: 25 А
- Contact Voltage AC Max: 220 В
- Mounting Type: Bracket
- No. of Poles: 2
- Operating Temperature Max: 60°C
- Series: G7L
- Temperature Operating Min: -25°C
- AC Coil Power: 2.5VA
- Approval Bodies: UL, CSA, VDE, IEC
- Coil Operating Lower Percent Limit: 75%
- Coil Operating Upper Percent Limit: 110%
- Coil Voltage Max: 240 В AC
- Coil Voltage Min: 200 В AC
- Switch Current Max: 20 А
- Switching Power Max: 5500VA
- Terminal Type: 6.35 мм x 0.8 мм
G7L2AT 200/240AC, G7L 2A T 200/240AC
