Datasheet G7L-2A-TUB-80-CB AC200/240 - Omron Даташит POWER Реле 240VAC — Даташит
Omron G7L-2A-TUB-80-CB AC200/240
Наименование модели: G7L-2A-TUB-80-CB AC200/240
Реле Мощности, Electromechanical Relay 200/240VAC 21KΩ 25A DPST-NO (( 68.5mm 33.5mm 47mm)) Bracket General Purpose Relay
G7L-2A-TUB-80-CB-AC200/240
Omron
671 ₽
G7L2ATUB80CBAC200240
Omron
790 ₽
G7L-2A-TUB80CBAC200240
Omron
831 ₽
Элитан
G7L-2A-TUB-80-CBAC200240
Omron
2 031 ₽
Производитель: Omron
Описание: POWER Реле 240VAC
data sheetСкачать Data Sheet
Power Relay
G7L
A High-capacity, High-dielectric-strength Relay Compatible with Momentary Voltage Drops
· No contact chattering for momentary voltage drops up to 50% of rated voltage.
· Wide-range AC-activated coil that handles 100 to 120 or 200 to 240 VAC at either 50 or 60 Hz. · Miniature hinge for maximum switching power, particularly for inductive loads. · Flame-resistance materials (UL94V-0-qualifying) used for all insulation material. · Quick-connect, screw, and PCB terminals, and DIN track mounting available.
Model Number Structure
  • Тип реле: General Purpose
  • Coil Voltage VAC Nom: 240 В
  • Coil Resistance: 21000 Ом
  • Contact Configuration: DPST N/O
  • Внешняя длина / высота: 47 мм
  • Внешняя ширина: 68.5 мм
  • External Depth: 33.5 мм
  • Contact Current AC Max: 25 А
  • Mounting Type: Plug In
  • No. of Poles: 2
  • Operating Temperature Max: 60°C
  • Series: G7L
  • Temperature Operating Min: -25°C
G7L2ATUB80CB AC200/240, G7L 2A TUB 80 CB AC200/240
На английском языке: Datasheet G7L-2A-TUB-80-CB AC200/240 - Omron POWER RELAY 240VAC
