Datasheet G8P-1A4P 24DC - Omron Даташит Реле, PCB, SPNO, 24 В DC — Даташит
Omron G8P-1A4P 24DC
Наименование модели: G8P-1A4P 24DC
T-electron
G8P1A4P24DC
Omron
7 374 ₽
ТаймЧипс
G8P-1A4P24DC
Omron
G8P1A4P24DC
G8P1A4P24DC
Производитель: Omron
Описание: Реле, PCB, SPNO, 24 В DC
data sheetСкачать Data Sheet
PCB Relay
Compact, Low-cost 30-A Power Relay for PC Board or Panel-mounted Applications
I I I I I I I I
New G8P
Compact, yet capable of switching up to 30-A loads.
Complies with UL873 and UL508 column A spacings (1/8" through air, 1/4" over surface). UL Class F insulation standard. Withstands of up to 6,000 V under 1.250 ms impulse wave or ring wave. A selection of contact forms: SPDT and SPSTNO. Quick-connect terminals versions ideal for PC board and panel mounting. Flanged mounting available. Ideal for home and industrial appliances, HVAC (heating, ventilating, and air conditioning), and many other applications.
  • Тип реле: Power
  • Coil Voltage VDC Nom: 24 В
  • Contact Current Max: 30 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 28 В
  • Coil Resistance: 660 Ом
  • Contact Configuration: SPST
  • Coil Type: DC Coil
  • Coil Current: 36 мА
  • Nom Operating Power: 900 мВт
  • Relay Mounting: PC Board
  • Внешняя длина / высота: 33.9 мм
  • Внешняя ширина: 28.2 мм
  • External Depth: 21.8 мм
  • Contact Current AC Max: 30 А
  • Contact Current DC Max: 20 А
  • Contact Voltage AC Max: 250 В
  • Contact Voltage DC Max: 28 В
  • Mounting Type: PCB
  • No. of Poles: 1
  • Operating Temperature Max: 105°C
  • Series: G8P
  • Temperature Operating Min: -55°C
  • Approval Bodies: CSA
  • Approval Category: UL Recognised
  • DC Coil Power: 900 мВт
  • Dielectric Strength VDC: 1.5kV
  • Operating Time: 15 мс
  • Release Time: 10 мс
  • Switch Current Max: 30 А
  • Вес: 31 г
G8P1A4P 24DC, G8P 1A4P 24DC
На английском языке: Datasheet G8P-1A4P 24DC - Omron RELAY, PCB, SPNO, 24 V DC
