Datasheet G8P-1C4P 12DC - Omron Даташит Реле, PCB, SPCO, 12 В DC — Даташит
Наименование модели: G8P-1C4P 12DC
![]() 20 предложений от 11 поставщиков Промышленные/Универсальные Реле, Electromechanical Relay SPDT 20/10A 12VDC 155Ω Through Hole | |||
G8P1C4P12DC Omron | 93 ₽ | ||
G8P1C4P12DC Omron | 99 ₽ | ||
G8P-1C4P-12DC Omron | от 511 ₽ | ||
G8P1C4P12DC | по запросу |
Производитель: Omron
Описание: Реле, PCB, SPCO, 12 В DC
PCB Relay
Compact, Low-cost 30-A Power Relay for PC Board or Panel-mounted Applications
I I I I I I I I
New G8P
Compact, yet capable of switching up to 30-A loads.
Complies with UL873 and UL508 column A spacings (1/8" through air, 1/4" over surface). UL Class F insulation standard. Withstands of up to 6,000 V under 1.250 ms impulse wave or ring wave. A selection of contact forms: SPDT and SPSTNO. Quick-connect terminals versions ideal for PC board and panel mounting. Flanged mounting available. Ideal for home and industrial appliances, HVAC (heating, ventilating, and air conditioning), and many other applications.
- Тип реле: Power
- Coil Voltage VDC Nom: 12 В
- Contact Current Max: 20 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 28 В
- Coil Resistance: 155 Ом
- Contact Configuration: SPDT
- Coil Type: DC Coil
- Coil Current: 77 мА
- Nom Operating Power: 900 мВт
- Relay Mounting: PC Board
- Внешняя длина / высота: 33.9 мм
- Внешняя ширина: 28.2 мм
- External Depth: 21.8 мм
- Contact Current AC Max: 30 А
- Contact Current DC Max: 15 А
- Contact Voltage AC Max: 250 В
- Contact Voltage DC Max: 28 В
- Mounting Type: PCB
- No. of Poles: 1
- Operating Temperature Max: 105°C
- Series: G8P
- Temperature Operating Min: -55°C
- Approval Bodies: CSA
- Approval Category: UL Recognised
- DC Coil Power: 900 мВт
- Dielectric Strength VDC: 1.5kV
- Operating Time: 15 мс
- Release Time: 10 мс
- Switch Current Max: 20 А
- Вес: 31 г
G8P1C4P 12DC, G8P 1C4P 12DC
