Источники питания Keen Side
Datasheet G8P-1C4TP 12DC - Omron Даташит Реле, PCB, SPCO, 12 В DC — Даташит
Omron G8P-1C4TP 12DC
Наименование модели: G8P-1C4TP 12DC
Промышленные/Универсальные Реле, Electromechanical Relay SPDT 20/10A 12VDC 155Ω Through Hole
G8P1C4TP12DC
Omron
88 ₽
G8P1C4TP12DC
Omron
124 ₽
Производитель: Omron
Описание: Реле, PCB, SPCO, 12 В DC
data sheetСкачать Data Sheet
PCB Relay
Compact, Low-cost 30-A Power Relay for PC Board or Panel-mounted Applications
G8P
Compact, yet capable of switching up to 30-A loads.
Complies with UL873 and UL508 column A spacings (1/8" through air, 1/4" over surface). UL Class F insulation standard. Withstands of up to 6,000 V under 1.2 Ч 50 µs impulse wave or ring wave. A selection of contact forms: SPDT and SPSTNO. Quick-connect terminals versions ideal for PC board and panel mounting. Flanged mounting available. Ideal for home and industrial appliances, HVAC (heating, ventilating, and air conditioning), and many other applications. RoHS Compliant
Refer to pages 16 to 17 for details.
  • Тип реле: Power
  • Coil Voltage VDC Nom: 12 В
  • Contact Current Max: 20 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 28 В
  • Coil Resistance: 155 Ом
  • Contact Configuration: SPDT
  • Coil Type: DC Coil
  • Coil Current: 77 мА
  • Nom Operating Power: 900 мВт
  • Relay Mounting: PC Board
  • Внешняя длина / высота: 28.3 мм
  • Внешняя ширина: 31.9 мм
  • External Depth: 27.5 мм
  • Contact Current AC Max: 20 А
  • Contact Current DC Max: 20 А
  • Contact Voltage AC Max: 250 В
  • Contact Voltage DC Max: 28 В
  • Mounting Type: PCB
  • No. of Poles: 1
  • Operating Temperature Max: 105°C
  • Series: G8P
  • Temperature Operating Min: -55°C
  • Type: Fully Sealed
  • Approval Bodies: CSA
  • Approval Category: UL Recognised
  • Coil Operating Lower Percent Limit: 10%
  • Coil Operating Upper Percent Limit: 75%
  • Contact Current Rating: 20 А
  • Contact Material: Ag Alloy
  • Contact Resistance: 100 MOhm
  • DC Coil Power: 900 мВт
  • Dielectric Voltage Coil to Contact: 2500 В AC
  • Dielectric Voltage Contact to Contact: 1500 В AC
  • Insulation Resistance: 100 MOhm
Дополнительные аксессуары:
  • DURATOOL - HT-502C
G8P1C4TP 12DC, G8P 1C4TP 12DC
На английском языке: Datasheet G8P-1C4TP 12DC - Omron RELAY, PCB, SPCO, 12 V DC
