Datasheet G9EA-1B 12DC - Omron Даташит Реле, SPNO, 60 А, 12 В DC — Даташит
Omron G9EA-1B 12DC
Наименование модели: G9EA-1B 12DC
Промышленные/Универсальные Реле, Electromechanical Relay SPST-NO 100A 12VDC 28.8Ω Flange Mount
G9EA1B12DC
Omron
10 837 ₽
G9EA1B12DC
Omron
13 493 ₽
G9EA1B12DC
Omron
14 180 ₽
T-electron
G9EA1B12DC
Omron
Производитель: Omron
Описание: Реле, SPNO, 60 А, 12 В DC
data sheetСкачать Data Sheet
TextPower Relay ­ G9EA-1 DC
Power Relays
3.
Coil Terminals B: M3.5 screw terminals Blank: Lead Wire Output 4. Special Functions CA: High-current conduction (100 A) Note: Power-saving Models (with auxiliary contacts function) are scheduled to be added to the lineup as special function models. Contact form Rated coil voltage 12 VDC 24 VDC 48 VDC 60 VDC 100 VDC Model SPST-NO G9EA-1-B G9EA-1 G9EA-1-B-CA G9EA-1-CA
DC Power Relays Capable of Interrupting High-voltage, Highcurrent Loads
A compact relay (73 x 36 x 67.2 mm (L x W x
  • Тип реле: Power
  • Coil Voltage VDC Nom: 12 В
  • Contact Current Max: 100 А
  • Contact Voltage DC Nom: 400 В
  • Coil Resistance: 28.8 Ом
  • Contact Configuration: SPST
  • Coil Type: DC Coil
  • Coil Current: 417 мА
  • Nom Operating Power: 5 Вт
  • Relay Mounting: Chassis
  • Внешняя длина / высота: 67.2 мм
  • Внешняя ширина: 73 мм
  • External Depth: 36 мм
  • Contact Current DC Max: 100 А
  • Contact Voltage DC Max: 400 В
  • Mounting Type: Panel
  • No. of Poles: 1
  • Operating Temperature Max: 70°C
  • Series: G9EA
  • Temperature Operating Min: -40°C
  • Coil Operating Lower Percent Limit: 8%
  • Coil Operating Upper Percent Limit: 75%
  • Contact Resistance: 30 MOhm
  • DC Coil Power: 5 Вт
  • Dielectric Voltage Coil to Contact: 2500 В AC
  • Dielectric Voltage Contact to Contact: 2500 В AC
  • Insulation Resistance: 1000 MOhm
  • No. of Electrical Operations: 1000
  • No. of Mechanical Operations: 200000
  • Operating Time: 50 мс
  • Release Time: 30 мс
  • Switching Current DC Max: 60 А
  • Terminal Type: M3.5 screw terminals
  • Вес: 310 г
G9EA1B 12DC, G9EA 1B 12DC
На английском языке: Datasheet G9EA-1B 12DC - Omron RELAY, SPNO, 60 A, 12 V DC
