Datasheet G9EC-1B 12DC - Omron Даташит Реле, SPNO, 200 А, 12 В DC — Даташит
Наименование модели: G9EC-1B 12DC
![]() Промышленные/Универсальные Реле, Relay SPST-NO screw terminal,200A 12Vdc | |||
G9EC1B12DC Omron | 18 300 ₽ | ||
G9EC1B12DC Omron | 19 239 ₽ | ||
G9EC1B12DC Omron | 30 123 ₽ |
Производитель: Omron
Описание: Реле, SPNO, 200 А, 12 В DC
DC TextPower Relay G9EC-1 DC Power Relays Capable of Interrupting High-voltage, Highcurrent Loads
A compact relay (98 x 44 x 86.7 mm (L x W x
H)) capable of switching 400V, 200 A DC loads.
(Capable of interrupting 1,000 A at 400 VDC max.)
The switching section and driving section are
gas-injected and hermetically sealed, allowing these compact relays to interrupt highcapacity loads. The sealed construction also requires no arc space, saves space, and helps ensure safe applications.
- Тип реле: Power
- Coil Voltage VDC Nom: 12 В
- Contact Current Max: 200 А
- Contact Voltage DC Nom: 400 В
- Coil Resistance: 12.8 Ом
- Contact Configuration: SPST
- Coil Type: DC Coil
- Coil Current: 938 мА
- Nom Operating Power: 11 Вт
- Relay Mounting: Chassis
- Внешняя длина / высота: 86.7 мм
- Внешняя ширина: 98 мм
- External Depth: 44 мм
- Contact Current DC Max: 200 А
- Contact Voltage DC Max: 400 В
- Mounting Type: Panel
- No. of Poles: 1
- Operating Temperature Max: 50°C
- Series: G9EC
- Temperature Operating Min: -40°C
- Approval Bodies: CSA, UL
- Approval Category: UL508
- Coil Operating Lower Percent Limit: 8%
- Coil Operating Upper Percent Limit: 75%
- Contact Resistance: 30 MOhm
- DC Coil Power: 11 Вт
- Dielectric Voltage Coil to Contact: 2500 В AC
- Dielectric Voltage Contact to Contact: 2500 В AC
- Insulation Resistance: 1000 MOhm
- No. of Electrical Operations: 3000
- No. of Mechanical Operations: 200000
- Operating Time: 50 мс
- Release Time: 30 мс
- Terminal Type: M3.5 screw terminals
- Вес: 560 г
G9EC1B 12DC, G9EC 1B 12DC
