Datasheet G9EC-1B 24DC - Omron Даташит Реле, SPNO, 200 А, 24 В DC — Даташит
Omron G9EC-1B 24DC
Наименование модели: G9EC-1B 24DC
Промышленные/Универсальные Реле, Electromechanical Relay 24VDC 51.2Ω 200A SPST-NO (98x44x86.7)mm Power Relay
G9EC1B24DC
Omron
19 687 ₽
G9EC1B24DC
Omron
22 103 ₽
G9EC1B24DC
Omron
22 605 ₽
G9EC1B24DC
Производитель: Omron
Описание: Реле, SPNO, 200 А, 24 В DC
data sheetСкачать Data Sheet
DC TextPower Relay ­ G9EC-1 DC Power Relays Capable of Interrupting High-voltage, Highcurrent Loads
A compact relay (98 x 44 x 86.7 mm (L x W x
H)) capable of switching 400V, 200 A DC loads.
(Capable of interrupting 1,000 A at 400 VDC max.)
The switching section and driving section are
gas-injected and hermetically sealed, allowing these compact relays to interrupt highcapacity loads. The sealed construction also requires no arc space, saves space, and helps ensure safe applications.
  • Тип реле: Power
  • Coil Voltage VDC Nom: 24 В
  • Contact Current Max: 200 А
  • Contact Voltage DC Nom: 400 В
  • Coil Resistance: 51.2 Ом
  • Contact Configuration: SPST
  • Coil Type: DC Coil
  • Coil Current: 969 мА
  • Nom Operating Power: 11 Вт
  • Relay Mounting: Chassis
  • Внешняя длина / высота: 86.7 мм
  • Внешняя ширина: 98 мм
  • External Depth: 44 мм
  • Contact Current DC Max: 200 А
  • Contact Voltage DC Max: 400 В
  • Mounting Type: Panel
  • No. of Poles: 1
  • Operating Temperature Max: 50°C
  • Series: G9EC
  • Temperature Operating Min: -40°C
  • Approval Bodies: CSA, UL
  • Approval Category: UL508
  • Coil Operating Lower Percent Limit: 8%
  • Coil Operating Upper Percent Limit: 75%
  • Contact Resistance: 30 MOhm
  • DC Coil Power: 11 Вт
  • Dielectric Voltage Coil to Contact: 2500 В AC
  • Dielectric Voltage Contact to Contact: 2500 В AC
  • Insulation Resistance: 1000 MOhm
  • No. of Electrical Operations: 3000
  • No. of Mechanical Operations: 200000
  • Operating Time: 50 мс
  • Release Time: 30 мс
  • Terminal Type: M3.5 screw terminals
  • Вес: 560 г
G9EC1B 24DC, G9EC 1B 24DC
На английском языке: Datasheet G9EC-1B 24DC - Omron RELAY, SPNO, 200 A, 24 V DC
