Datasheet LY2-AC24 - Omron Даташит Реле, PLUG IN, DPDT, 24VAC — Даташит
Omron LY2-AC24
Наименование модели: LY2-AC24
25 предложений от 14 поставщиков
Реле Мощности, OMRON INDUSTRIAL AUTOMATION LY2-AC24 Power Relay, DPDT, 24VAC, 15A, LY Series, Through Hole, Non Latching
LY2AC24
Omron
661 ₽
LY2AC24
Omron
704 ₽
DIP8.RU
Россия и страны ТС
LY2-AC24
Omron
от 1 539 ₽
LY2-AC24
Omron
от 1 890 ₽
Производитель: Omron
Описание: Реле, PLUG IN, DPDT, 24VAC
data sheetСкачать Data Sheet
General Purpose Relay
LY
· Arc barrier equipped.
· High dielectric strength (2,000 VAC). · Long dependable service life assured by Ag-Alloy contacts. · Choose models with single or bifurcated contacts, LED indicator, diode surge suppression, push-to-test button, or RC circuit. · UL, CSA, TUV, and CE approvals on all standard LY Relay Part Numbers.
Ordering Information
To Order: Select the part number and add the desired coil voltage rating (e.g., LY1-DC6). Type Terminal Contact form Model Single contact Standard bracket mounting Standard Plug-in/solder SPDT DPDT 3PDT 4PDT PCB SPDT DPDT 3PDT 4PDT LED indicator Plug-in/solder SPDT DPDT 3PDT 4PDT Diode surge suppression SPDT DPDT 3PDT 4PDT LED indicator and diode surge suppression RC circuit LED indicator and RC circuit SPDT DPDT 4PDT SPDT DPDT SPDT DPDT LY1 LY2 LY3 LY4 LY1-0 LY2-0 LY3-0 LY4-0 LY1N LY2N LY3N LY4N LY1-D LY2-D LY3-D LY4-D LY1N-D2 LY2N-D2 LY4N-D2 LY1-CR LY2-CR LY1N-CR LY2N-CR Upper mounting bracket LY1F LY2F LY3F LY4F -- -
  • Тип реле: General Purpose
  • Coil Voltage VAC Nom: 24 В
  • Contact Current Max: 10 А
  • Contact Voltage AC Nom: 110 В
  • Contact Voltage DC Nom: 24 В
  • Coil Resistance: 180 Ом
  • Contact Configuration: DPDT
  • Coil Type: AC Coil
  • Coil Current: 53.8 мА
  • Nom Operating Power: 1.2VA
  • Relay Mounting: Plug-In
  • Внешняя длина / высота: 36 мм
  • Внешняя ширина: 21.59 мм
  • External Depth: 27.94 мм
  • Contact Current AC Max: 10 А
  • Contact Current DC Max: 10 А
  • Contact Voltage AC Max: 250 В
  • Contact Voltage DC Max: 125 В
  • Mounting Type: Plug-In
  • No. of Poles: 2
  • Series: LY
Дополнительные аксессуары:
  • Omron - P6B-C2
  • Omron - PT08-0
LY2AC24, LY2 AC24
На английском языке: Datasheet LY2-AC24 - Omron RELAY, PLUG IN, DPDT, 24VAC
