Datasheet LY2-DC48 - Omron Даташит Реле, PLUG IN, DPDT, 48 В DC — Даташит
Наименование модели: LY2-DC48
![]() 20 предложений от 11 поставщиков Промышленные/Универсальные Реле, Electromechanical Relay DPDT 10A 48VDC 2.6KΩ Socket | |||
LY2DC48 Omron | 650 ₽ | ||
LY2DC48 Omron | от 1 499 ₽ | ||
LY2-DC48 Omron | от 3 200 ₽ | ||
LY2-DC48 Omron | по запросу |
Производитель: Omron
Описание: Реле, PLUG IN, DPDT, 48 В DC
General Purpose Relay
LY
· Arc barrier equipped.
· High dielectric strength (2,000 VAC). · Long dependable service life assured by Ag-Alloy contacts. · Choose models with single or bifurcated contacts, LED indicator, diode surge suppression, push-to-test button, or RC circuit. · UL, CSA, TUV, and CE approvals on all standard LY Relay Part Numbers.
Ordering Information
To Order: Select the part number and add the desired coil voltage rating (e.g., LY1-DC6). Type Terminal Contact form Model Single contact Standard bracket mounting Standard Plug-in/solder SPDT DPDT 3PDT 4PDT PCB SPDT DPDT 3PDT 4PDT LED indicator Plug-in/solder SPDT DPDT 3PDT 4PDT Diode surge suppression SPDT DPDT 3PDT 4PDT LED indicator and diode surge suppression RC circuit LED indicator and RC circuit SPDT DPDT 4PDT SPDT DPDT SPDT DPDT LY1 LY2 LY3 LY4 LY1-0 LY2-0 LY3-0 LY4-0 LY1N LY2N LY3N LY4N LY1-D LY2-D LY3-D LY4-D LY1N-D2 LY2N-D2 LY4N-D2 LY1-CR LY2-CR LY1N-CR LY2N-CR Upper mounting bracket LY1F LY2F LY3F LY4F -- -
- Тип реле: General Purpose
- Coil Voltage VDC Nom: 48 В
- Contact Current Max: 10 А
- Contact Voltage AC Nom: 110 В
- Contact Voltage DC Nom: 24 В
- Coil Resistance: 2.6 кОм
- Contact Configuration: DPDT
- Coil Type: DC Coil
- Coil Current: 18.5 мА
- Nom Operating Power: 900 мВт
- Relay Mounting: Plug-In
- Внешняя длина / высота: 36 мм
- Внешняя ширина: 21.59 мм
- External Depth: 27.94 мм
- Contact Current AC Max: 10 А
- Contact Current DC Max: 10 А
- Contact Voltage AC Max: 250 В
- Contact Voltage DC Max: 125 В
- Mounting Type: Plug-In
- No. of Poles: 2
- Series: LY
Дополнительные аксессуары:
- Omron - P6B-C2
- Omron - PT08-0
LY2DC48, LY2 DC48
