Datasheet LY3-DC24 - Omron Даташит Реле, 3PDT, 24 В DC — Даташит
Наименование модели: LY3-DC24
![]() 17 предложений от 10 поставщиков Реле Мощности, OMRON INDUSTRIAL AUTOMATION LY3-DC24 Power Relay, 3PDT, 24VDC, 10A, LY Series, Through Hole, Non Latching | |||
LY3-DC24 Omron | 566 ₽ | ||
LY3-DC24 Omron | от 2 844 ₽ | ||
LY3-DC24 Omron | 2 937 ₽ |
Производитель: Omron
Описание: Реле, 3PDT, 24 В DC
General-purpose Relay
LY
A Miniature Power Relay
· Equipped with arc barrier.
· Dielectric strength: 2,000 V. · Built-in diode models added to the LY Series. · Single-pole and double-pole models are applicable to operating coils with ratings of 100/110 VAC, 110/120 VAC, 200/220 VAC, 220/240 VAC, or 100/110 VDC). · Three-pole and four-pole models are applicable to operating coils with ratings of 100/110 VAC, 200/220 VAC, or 100/110 VDC).
LR
- Тип реле: General Purpose
- Coil Voltage VDC Nom: 24 В
- Contact Current Max: 10 А
- Contact Voltage AC Nom: 110 В
- Contact Voltage DC Nom: 24 В
- Coil Resistance: 410 Ом
- Contact Configuration: 3PDT
- Coil Type: DC Coil
- Coil Current: 58.6 мА
- Nom Operating Power: 1.4 Вт
- Relay Mounting: Plug-In
- Внешняя длина / высота: 36.5 мм
- Внешняя ширина: 31.5 мм
- External Depth: 28 мм
- Contact Current AC Max: 10 А
- Contact Current DC Max: 10 А
- Contact Voltage AC Max: 250 В
- Contact Voltage DC Max: 125 В
- Mounting Type: Plug-In
- No. of Poles: 3
- Operating Temperature Max: 40°C
- Series: LY
- Temperature Operating Min: -25°C
- Type: Standard
- Approval Bodies: CE, CSA, SEV, VDE, LR
- Approval Category: UL Recognised
- Contact Current Rating: 10 А
- Contact Resistance: 50 MOhm
- DC Coil Power: 1.4 Вт
- Dielectric Voltage Contact to Contact: 1000 В AC
- Insulation Resistance: 100Mohm
- Operating Time
- Release Time: 25 мс
- Switching Power Max: 240 Вт
- Switching Voltage AC: 110 В AC
- Switching Voltage DC: 24 В DC
- Terminal Type: Plug-in/solder
Дополнительные аксессуары:
- COOPER TOOLS / WELLER - SD1000
LY3DC24, LY3 DC24
