Datasheet MY4ZN DC24(S) - Omron Даташит Реле, 4PDT 24 В DC — Даташит
Наименование модели: MY4ZN DC24(S)
![]() 9 предложений от 9 поставщиков Relay; E-Mech; 4PDT; Ctrl-V 24DC; 5A; 250VAC/125VDC; Socket Mount; Blade Term; MY Series | |||
MY4ZN-DC24(S) Omron | 994 ₽ | ||
MY4ZN-DC24(S) Omron | по запросу | ||
MY4ZNDC24 Omron | по запросу | ||
MY4ZN-DC24-S Omron | по запросу |
Производитель: Omron
Описание: Реле, 4PDT 24 В DC
General-purpose Relay
MY New model
Versatile and Function-filled Miniature Power Relay for Sequence Control and Power Switching Applications
· Models with lockable test buttons now available.
· Many variations possible through a selection of operation indicators (mechanical and LED indicators), lockable test button, built-in diode and CR (surge suppression), bifurcated contacts, etc. · Arc barrier standard on 4-pole Relays. · Dielectric strength: 2,000 VAC (coil to contact) · Environment-friendly cadmium-free contacts. · Safety standard approvals obtained. · Wide range of Sockets (PY, PYF Series) and optional parts are available. · Max. Switching Current: 2-pole: 10 A, 4-pole: 5 A · Provided with nameplate.
LR
- Тип реле: General Purpose
- Coil Voltage VDC Nom: 24 В
- Contact Current Max: 5 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 636 Ом
- Contact Configuration: 4PDT
- Coil Type: DC Coil
- Coil Current: 37.7 мА
- Nom Operating Power: 900 мВт
- Relay Mounting: Plug-In
- Внешняя длина / высота: 36 мм
- Внешняя ширина: 28 мм
- External Depth: 21.5 мм
- Contact Current AC Max: 3 А
- Contact Current DC Max: 3 А
- Contact Voltage AC Max: 250 В
- Contact Voltage DC Max: 125 В
- Mounting Type: Plug-In
- No. of Poles: 4
- Operating Temperature Max: 70°C
- Series: MY
- Temperature Operating Min: -55°C
- Type: Standard with LED indicator
- Approval Bodies: CE, VDE, CSA, SEV, IMQ, LR
- Approval Category: UL Recognised
- Contact Resistance: 100 MOhm
- DC Coil Power: 0.9 Вт
- Dielectric Voltage Coil to Contact: 2000 В AC
- Dielectric Voltage Contact to Contact: 1000 В AC
- Insulation Resistance: 1000 MOhm
- Operating Time: 20 мс
- Release Time: 20 мс
- Switching Power Max: 150 Вт
- Switching Voltage AC: 250 В AC
Дополнительные аксессуары:
- COOPER TOOLS / WELLER - SD1000
