Datasheet G2R-1-E-DC24 - Omron Даташит POWER Реле, SPDT, 24 В DC, 16 А, PC BOARD — Даташит
Наименование модели: G2R-1-E-DC24
![]() 35 предложений от 19 поставщиков Реле электромагнитное, SPDT, на печатную плату, Uобмотки 24ВDC, 16A/250ВAC, шаг 5мм | |||
G2R-1-E-DC24 Omron | 73 ₽ | ||
G2R-1-E-DC24 Omron | от 215 ₽ | ||
G2R-1-E-DC24 Omron | от 336 ₽ | ||
G2R-1-E-DC24 Omron | по запросу |
Производитель: Omron
Описание: POWER Реле, SPDT, 24 В DC, 16 А, PC BOARD
Power PCB Relay
G2R
· Creepage distance of 8.0 mm min.
between coil and contact. · Dual-winding latching type available. · Plug-in and quick-connect terminals available (see G2R-S(S) data sheet). · High sensitivity (360 mW) and high capacity (16 A) types available. · Highly stable magnetic circuit for latching endurance and excellent resistance to vibration and shock. · Safety-oriented design assuring high surge resistance: 10,000 V min. between coil and contacts. · UL recognized / CSA certified. RoHS Complaint
Ordering Information
To order: Select the part number and add the desired coil voltage rating (e.g., G2R-14-DC12).
- Тип реле: High Capacity
- Coil Voltage VDC Nom: 24 В
- Contact Current Max: 16 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 1100 Ом
- Contacts: SPDT
- Coil Type: DC
G2R1EDC24, G2R 1 E DC24
