Datasheet G2R-1-E-DC5 - Omron Даташит POWER Реле, SPDT, 5 В DC, 16 А, PC BOARD — Даташит
Наименование модели: G2R-1-E-DC5
![]() 25 предложений от 15 поставщиков Промышленные/Универсальные Реле, Electromechanical Relay SPDT 16A 5VDC 47Ω Through Hole | |||
G2R1EDC5BYOMI Omron | 114 ₽ | ||
G2R-1-E-DC5 Omron | 191 ₽ | ||
G2R-1-E-DC5 Omron | от 366 ₽ | ||
G2R-1-E-DC5 Omron | от 1 073 ₽ |
Производитель: Omron
Описание: POWER Реле, SPDT, 5 В DC, 16 А, PC BOARD
Power PCB Relay
G2R
· Creepage distance of 8.0 mm min.
between coil and contact. · Dual-winding latching type available. · Plug-in and quick-connect terminals available (see G2R-S(S) data sheet). · High sensitivity (360 mW) and high capacity (16 A) types available. · Highly stable magnetic circuit for latching endurance and excellent resistance to vibration and shock. · Safety-oriented design assuring high surge resistance: 10,000 V min. between coil and contacts. · UL recognized / CSA certified. RoHS Complaint
Ordering Information
To order: Select the part number and add the desired coil voltage rating (e.g., G2R-14-DC12).
- Тип реле: High Capacity
- Coil Voltage VDC Nom: 5 В
- Contact Current Max: 16 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 47 Ом
- Contacts: SPDT
- Coil Type: DC
G2R1EDC5, G2R 1 E DC5
