Клеммные колодки Keen Side
Datasheet G2R-14-AC120 - Omron Даташит POWER Реле, SPDT, 120VAC, 10 А, PC BOARD — Даташит
Omron G2R-14-AC120
Наименование модели: G2R-14-AC120
18 предложений от 12 поставщиков
Промышленные/Универсальные Реле, Electromechanical Relay SPDT 10A 120VAC 6.5KΩ Through Hole
G2R14AC120BYOMI
Omron
544 ₽
G2R-14-AC120
Omron
946 ₽
Элитан
G2R14AC120
Omron
1 269 ₽
G2R-14-AC120
Производитель: Omron
Описание: POWER Реле, SPDT, 120VAC, 10 А, PC BOARD
data sheetСкачать Data Sheet
Power PCB Relay
G2R
· Creepage distance of 8.0 mm min.
between coil and contact. · Dual-winding latching type available. · Plug-in and quick-connect terminals available (see G2R-S(S) data sheet). · High sensitivity (360 mW) and high capacity (16 A) types available. · Highly stable magnetic circuit for latching endurance and excellent resistance to vibration and shock. · Safety-oriented design assuring high surge resistance: 10,000 V min. between coil and contacts. · UL recognized / CSA certified. RoHS Complaint
Ordering Information
To order: Select the part number and add the desired coil voltage rating (e.g., G2R-14-DC12).
  • Тип реле: General Purpose
  • Coil Voltage VAC Nom: 120 В
  • Contact Current Max: 10 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 6500 Ом
  • Contacts: SPDT
  • Coil Type: AC
G2R14AC120, G2R 14 AC120
На английском языке: Datasheet G2R-14-AC120 - Omron POWER RELAY, SPDT, 120VAC, 10 A, PC BOARD
