Datasheet G2R-14-AC24 - Omron Даташит POWER Реле, SPDT, 24VAC, 10 А, PC BOARD — Даташит
Наименование модели: G2R-14-AC24
![]() 19 предложений от 12 поставщиков Реле Мощности, Power Relay 24VAC 10A SPDT (( 29mm 13.5mm 25.5mm)) Through Hole | |||
G2R-14-AC24 Omron | 286 ₽ | ||
G2R-14-AC24 Omron | от 1 692 ₽ | ||
G2R-14-AC24 | по запросу | ||
G2R-14-AC24 Omron | по запросу |
Производитель: Omron
Описание: POWER Реле, SPDT, 24VAC, 10 А, PC BOARD
Power PCB Relay
G2R
· Creepage distance of 8.0 mm min.
between coil and contact. · Dual-winding latching type available. · Plug-in and quick-connect terminals available (see G2R-S(S) data sheet). · High sensitivity (360 mW) and high capacity (16 A) types available. · Highly stable magnetic circuit for latching endurance and excellent resistance to vibration and shock. · Safety-oriented design assuring high surge resistance: 10,000 V min. between coil and contacts. · UL recognized / CSA certified. RoHS Complaint
Ordering Information
To order: Select the part number and add the desired coil voltage rating (e.g., G2R-14-DC12).
- Тип реле: General Purpose
- Coil Voltage VAC Nom: 24 В
- Contact Current Max: 10 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 260 Ом
- Contacts: SPDT
- Coil Type: AC
G2R14AC24, G2R 14 AC24
