Datasheet G2R-14-AC240 - Omron Даташит POWER Реле, SPDT, 240VAC, 10 А, PC BOARD — Даташит
Omron G2R-14-AC240
Наименование модели: G2R-14-AC240
20 предложений от 12 поставщиков
Реле: электромагнитное; SPDT; Uобмотки: 240ВAC; 8А; 8A/250ВAC; PCB
G2R14AC240BYOMI
Omron
852 ₽
ЭИК
G2R-14-AC240
Omron
от 3 187 ₽
G2R-14-AC240
от 3 693 ₽
T-electron
G2R14AC240
132 753 ₽
Производитель: Omron
Описание: POWER Реле, SPDT, 240VAC, 10 А, PC BOARD
data sheetСкачать Data Sheet
Power PCB Relay
G2R
· Creepage distance of 8.0 mm min.
between coil and contact. · Dual-winding latching type available. · Plug-in and quick-connect terminals available (see G2R-S(S) data sheet). · High sensitivity (360 mW) and high capacity (16 A) types available. · Highly stable magnetic circuit for latching endurance and excellent resistance to vibration and shock. · Safety-oriented design assuring high surge resistance: 10,000 V min. between coil and contacts. · UL recognized / CSA certified. RoHS Complaint
Ordering Information
To order: Select the part number and add the desired coil voltage rating (e.g., G2R-14-DC12).
  • Тип реле: General Purpose
  • Coil Voltage VAC Nom: 240 В
  • Contact Current Max: 10 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 30000 Ом
  • Contacts: SPDT
  • Coil Type: AC
G2R14AC240, G2R 14 AC240
На английском языке: Datasheet G2R-14-AC240 - Omron POWER RELAY, SPDT, 240VAC, 10 A, PC BOARD
