Datasheet G2R-1A-E-T130 DC24 - Omron Даташит POWER Реле SPST-NO 24 В DC, 16 А, PC BOARD — Даташит
Omron G2R-1A-E-T130 DC24
Наименование модели: G2R-1A-E-T130 DC24
11 предложений от 8 поставщиков
Реле общего назначения Power PCB Relay SPST 16A 24VDC
G2R1AET130DC24
Omron
168 ₽
G2R1AET130DC24
Omron
322 ₽
Элитан
G2R-1A-E-T130-DC24
Omron
875 ₽
G2R-1A-E-T130-DC24
Производитель: Omron
Описание: POWER Реле SPST-NO 24 В DC, 16 А, PC BOARD
data sheetСкачать Data Sheet
Power PCB Relay
G2R
· Creepage distance of 8.0 mm min.
between coil and contact. · Dual-winding latching type available. · Plug-in and quick-connect terminals available (see G2R-S(S) data sheet). · High sensitivity (360 mW) and high capacity (16 A) types available. · Highly stable magnetic circuit for latching endurance and excellent resistance to vibration and shock. · Safety-oriented design assuring high surge resistance: 10,000 V min. between coil and contacts. · UL recognized / CSA certified. RoHS Complaint
Ordering Information
To order: Select the part number and add the desired coil voltage rating (e.g., G2R-14-DC12).
  • Тип реле: High Capacity
  • Coil Voltage VDC Nom: 24 В
  • Contact Current Max: 16 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 1100 Ом
  • Contacts: SPST-NO
  • Coil Type: DC
G2R1AET130 DC24, G2R 1A E T130 DC24
На английском языке: Datasheet G2R-1A-E-T130 DC24 - Omron POWER RELAY SPST-NO 24 V DC, 16 A, PC BOARD
