isc N-Channel MOSFET Transistor FDD86110 FEATURES Drain Current : ID= 50A@ TC=25℃ Drain Source Voltage
: VDSS= 100V(Min) Static Drain-Source On-Resistance
: RDS(on) = 10.2mΩ(Max) 100% avalanche tested Minimum Lot-to-Lot variations for robust device
performance and reliable operation
DESCRIPTION motor drive, DC-DC converter, power switch
and solenoid drive.
ABSOLUTE MAXIMUM RATINGS(Ta=25℃)
SYMBOL PARAMETER VALUE UNIT VDSS Drain-Source Voltage 100 V VGS Gate-Source Voltage-Continuous ±20 V ID Drain Current-Continuous 50 A IDM Drain Current-Single Pluse 60 A PD Total Dissipation @TC=25℃ 127 W TJ Max. Operating Junction Temperature 150 ℃ -55~150 ℃ Tstg Storage Temperature THERMAL CHARACTERISTICS
SYMBOL PARAMETER MAX UNIT Rth j-c Thermal Resistance, Junction to Case 0.98 ℃/W isc website:www.iscsemi.com 1 isc & iscsemi is registered trademark isc N-Channel MOSFET Transistor FDD86110 ELECTRICAL CHARACTERISTICS
TC=25℃ unless otherwise specified
SYMBOL
V(BR)DSS PARAMETER CONDITIONS MIN MAX UNIT 100 -V Drain-Source Breakdown Voltage VGS= 0; ID= 0.25mA VGS(th) Gate Threshold Voltage VDS= 10V; ID= 0.25mA 2 4 V RDS(on) Drain-Source On-Resistance VGS= 10V; ID= 12.5A -10.2 mΩ IGSS Gate-Body Leakage Current VGS= ±20V;VDS= 0 -±0.1 uA IDSS Zero Gate Voltage Drain Current VDS= 80V; VGS= 0 -1.0 uA VSD Forward On-Voltage IS= 12.5A; VGS= 0 -1.3 V NOTICE:
ISC reserves the rights to make changes of the content herein the datasheet at any time without
notification. The information contained herein is presented only as a guide for the applications of
our products.
ISC products are intended for usage in general electronic equipment. The products are not
designed for use in equipment which require specialized quality and/or reliability, or in equipment
which could have applications in hazardous environments, aerospace industry, or medical
field. Please contact us if you intend our products to be used in these special applications.
ISC makes no warranty or guarantee regarding the suitability of its products for any particular
purpose, nor does ISC assume any liability arising from the application or use of any products, and
specifically disclaims any and all liability, including without limitation special, consequential or
incidental damages. isc website:www.iscsemi.com 2 isc & iscsemi is registered trademark …
