PDF, 443 Кб, Язык: анг., Файл закачен: 19 мар 2026, Страниц: 9
Multi SMD Chip LED RGB in 0404 package
VLMRGB1500
www.vishay.com Vishay Semiconductors Multi SMD Chip LED RGB
FEATURES
• Utilizing high brightness AlInGaP and InGaN
chip technologies
• 4 pin RGB SMD LED package allows
individual control of the driving current of
each chip
• Compact package outline dimensions
(L x W x H in mm): 1.0 x 1.0 x 0.65
• Qualified according to JEDEC® moisture
sensitivity level 3
• Compatible to IR reflow soldering DESCRIPTION • Operation temperature range: -40 °C to +85 °C The VLMRGB1500. is a high brightness tricolor LED
designed primarily for RGB displays and backlights. It is
using the popular PCB based 0404 SMD package with 120°
emission characteristic. The 4 pin package with common
anode allows individual driving of each chip and thus a
gapless coverage of a wide color space by additive color
mixing. It provides high reliability in a temperature range
from -40 °C to +85 °C, using highly suitable blue light stable
package materials. • ESD-withstand voltage: up to 2 kV for red and 1 kV for
blue and green according to JESD22-A114-B
• Luminous intensities and colors categorized per reel …
