Клеммные колодки Keen Side
Datasheet G9EA-1BCA 24DC - Omron Даташит Реле, SPNO, 40 А, 24 В DC — Даташит
Omron G9EA-1BCA 24DC
Наименование модели: G9EA-1BCA 24DC
6 предложений от 4 поставщиков
Промышленные/Универсальные Реле, Electromechanical Relay SPST-NO 30A 24VDC 115.2Ω Flange Mount
Зенер
Россия и страны ТС
G9EA1BCA24DC
от 7 232 ₽
G9EA1BCA24DC
Omron
7 977 ₽
G9EA1BCA24DC
Omron
17 119 ₽
T-electron
G9EA1BCA24DC
1 374 547 ₽
Производитель: Omron
Описание: Реле, SPNO, 40 А, 24 В DC
data sheetСкачать Data Sheet
TextPower Relay ­ G9EA-1 DC
Power Relays
3.
Coil Terminals B: M3.5 screw terminals Blank: Lead Wire Output 4. Special Functions CA: High-current conduction (100 A) Note: Power-saving Models (with auxiliary contacts function) are scheduled to be added to the lineup as special function models. Contact form Rated coil voltage 12 VDC 24 VDC 48 VDC 60 VDC 100 VDC Model SPST-NO G9EA-1-B G9EA-1 G9EA-1-B-CA G9EA-1-CA
DC Power Relays Capable of Interrupting High-voltage, Highcurrent Loads
A compact relay (73 x 36 x 67.2 mm (L x W x
  • Тип реле: Power
  • Coil Voltage VDC Nom: 24 В DC
  • Coil Resistance: 115.2 Ом
  • Contact Configuration: SPST N/O
  • Coil Current: 208 мА
  • Внешняя длина / высота: 67.2 мм
  • Внешняя ширина: 73 мм
  • External Depth: 36 мм
  • Contact Current DC Max: 100 А
  • Contact Voltage DC Max: 400 В DC
  • Mounting Type: Panel
  • No. of Poles: 1
  • Operating Temperature Max: 70°C
  • Series: G9EA
  • Temperature Operating Min: -40°C
  • Coil Operating Lower Percent Limit: 8%
  • Coil Operating Upper Percent Limit: 75%
  • Contact Resistance: 10 MOhm
  • DC Coil Power: 5 Вт
  • Dielectric Voltage Coil to Contact: 2500 В AC
  • Dielectric Voltage Contact to Contact: 2500 В AC
  • Insulation Resistance: 1000 MOhm
  • No. of Electrical Operations: 1000
  • No. of Mechanical Operations: 200000
  • Operating Time: 50 мс
  • Release Time: 30 мс
  • Switching Current DC Max: 30 А
  • Terminal Type: M3.5 screw terminals
  • Вес: 310 г
Дополнительные аксессуары:
  • Omron - G9EA-1B 24DC
G9EA1BCA 24DC, G9EA 1BCA 24DC
На английском языке: Datasheet G9EA-1BCA 24DC - Omron RELAY, SPNO, 40 A, 24 V DC
