Datasheet G5JS-1A 24DC - Omron Даташит Реле, PCB, SPNO, 24 В DC — Даташит
Наименование модели: G5JS-1A 24DC
G5JS-1A-NTDC12V | по запросу | ||
G5JS-1A-S DC24 Omron | по запросу |
Производитель: Omron
Описание: Реле, PCB, SPNO, 24 В DC
PCB Relay
Ideal for Microwave Oven Magnetrons and Heater Switching
Clearance/Creepage distance of 8mm min.
Confirmed to VDE0700 High Impulse Withstand Voltage .( 10kV ) High Dielectric Strength ( 5kV) Approved by UL,CSA and VDE Environment Friendly Contact Material. Quick-Connect Terminal ( #187) and PCB terminal available
G5JS
VDE
- Тип реле: Power
- Coil Voltage VDC Nom: 24 В
- Contact Current Max: 16 А
- Contact Voltage AC Nom: 250 В
- Coil Resistance: 1.087 кОм
- Contact Configuration: SPNO
- Coil Type: DC Coil
- Coil Current: 22.1 мА
- Nom Operating Power: 530 мВт
- Relay Mounting: PC Board
- Внешняя длина / высота: 24.8 мм
- Внешняя ширина: 27.3 мм
- External Depth: 12.9 мм
- Contact Current AC Max: 16 А
- Contact Current DC Max: 16 А
- Contact Voltage AC Max: 250 В
- Contact Voltage DC Max: 30 В
- Mounting Type: PCB
- No. of Poles: 1
- Operating Temperature Max: 85°C
- Series: G5JS
- Temperature Operating Min: -40°C
- Approval Bodies: CSA, VDE
- Approval Category: UL Recognised
- Coil Operating Lower Percent Limit: 70%
- Coil Operating Upper Percent Limit: 110%
- Contact Resistance: 100 MOhm
- DC Coil Power: 530mW
- Dielectric Strength
- Dielectric Voltage Coil to Contact: 5000 В AC
- Dielectric Voltage Contact to Contact: 1000 В AC
- Insulation Resistance: 1000 MOhm
- Количество выводов: 4
- Operating Time: 15 мс
- Release Time: 5 мс
- Row Pitch: 7.6 мм
G5JS1A 24DC, G5JS 1A 24DC
