Datasheet ATMEGA48A-PU - Atmel Даташит Микроконтроллеры (MCU) AVR 4 Кб FLSH 256B EE 512B SRAM-20MHz IND — Даташит
Atmel ATMEGA48A-PU
Наименование модели: ATMEGA48A-PU
Микросхема Микроконтроллер, MCU 8Bit ATmega AVR RISC 4KB Flash 2.5V/3.3V/5V 28Pin PDIP W
ATMEGA48A-PU
от 53 ₽
ATMEGA48A-PU
79 ₽
ATMEGA48A-PU
Atmel
121 ₽
ATMEGA48A-PU
от 154 ₽
Производитель: Atmel
Описание: Микроконтроллеры (MCU) AVR 4 Кб FLSH 256B EE 512B SRAM-20MHz IND
data sheetСкачать Data Sheet
Features
· High Performance, Low Power AVR® 8-Bit Microcontroller · Advanced RISC Architecture
­ 131 Powerful Instructions ­ Most Single Clock Cycle Execution ­ 32 x 8 General Purpose Working Registers ­ Fully Static Operation ­ Up to 20 MIPS Throughput at 20 MHz ­ On-chip 2-cycle Multiplier High Endurance Non-volatile Memory Segments ­ 4/8/16/32K Bytes of In-System Self-Programmable Flash program memory ­ 256/512/512/1K Bytes EEPROM ­ 512/1K/1K/2K Bytes Internal SRAM ­ Write/Erase Cycles: 10,000 Flash/100,000 EEPROM ­ Data retention: 20 years at 85°C/100 years at 25°C(1) ­ Optional Boot Code Section with Independent Lock Bits In-System Programming by On-chip Boot Program True Read-While-Write Operation ­ Programming Lock for Software Security Peripheral Features ­ Two 8-bit Timer/Counters with Separate Prescaler and Compare Mode ­ One 16-bit Timer/Counter with Separate Prescaler, Compare Mode, and Capture Mode ­ Real Time Counter with Separate Oscillator ­ Six PWM Channels ­ 8-channel
  • Шина данных: 8 бит
  • Ядро: AVR
  • RoHS: да
ATMEGA48APU, ATMEGA48A PU
На английском языке: Datasheet ATMEGA48A-PU - Atmel Microcontrollers (MCU) AVR 4 Kb FLSH 256B EE 512B SRAM-20MHz IND
