Datasheet ATSAM3S1AA-AU - Atmel Даташит Микроконтроллеры (MCU) MRL А 64K Flash 16K SRAM Ind Temp — Даташит
Наименование модели: ATSAM3S1AA-AU
Купить ATSAM3S1AA-AU на РадиоЛоцман.Цены — от 72 до 2 366 ₽ 18 предложений от 12 поставщиков ARM® Cortex®-M3 SAM3S Microcontroller IC 32-Bit Single-Core 64MHz 64KB (64K x 8) FLASH 48-LQFP (7x7) | |||
ATSAM3S1AA-AU Microchip | 72 ₽ | ||
ATSAM3S1AA-AU Atmel | 126 ₽ | ||
ATSAM3S1AA-AU Microchip | 329 ₽ | ||
ATSAM3S1AA-AU Microchip | по запросу |
Производитель: Atmel
Описание: Микроконтроллеры (MCU) MRL А 64K Flash 16K SRAM Ind Temp
Features
· Core
ARM® Cortex®-M3 revision 2.0 running at up to 64 MHz Memory Protection Unit (MPU) Thumb®-2 instruction set Pin-to-pin compatible with AT91SAM7S legacy products (48- and 64-pin versions) Memories From 64 to 256 Kbytes embedded Flash, 128-bit wide access, memory accelerator, single plane From 16 to 48 Kbytes embedded SRAM 16 Kbytes ROM with embedded bootloader routines (UART, USB) and IAP routines 8-bit Static Memory Controller (SMC): SRAM, PSRAM, NOR and NAND Flash support Memory Protection Unit (MPU) System Embedded voltage regulator for single supply operation Power-on-Reset (POR), Brown-out Detector (BOD) and Watchdog for safe operation Quartz or ceramic resonator oscillators: 3 to 20 MHz main power with Failure Detection and optional low power 32.768 kHz for RTC or device clock High precision 8/12 MHz factory trimmed internal RC oscillator with 4 MHz default frequency for device startup.
In-application trimming access for frequency adjustment
- Серия процессора: ATSAM3x
- Ядро: ARM Cortex M3
- RoHS: да
ATSAM3S1AAAU, ATSAM3S1AA AU
