Datasheet ATSAM3S1BA-AU - Atmel Даташит Микроконтроллеры (MCU) MRL А 64K Flash 16K SRAM Ind Temp — Даташит
Наименование модели: ATSAM3S1BA-AU
![]() 12 предложений от 12 поставщиков Микросхема Микроконтроллер, MCU 32Bit SAM3S ARM Cortex M3 RISC 64KB Flash 1.8V/3.3V 64Pin LQFP | |||
ATSAM3S1BA-AU Microchip | 65 ₽ | ||
ATSAM3S1BA-AU Atmel | 229 ₽ | ||
ATSAM3S1BA-AU Microchip | 232 ₽ | ||
ATSAM3S1BA-AU Atmel | 639 ₽ |
Производитель: Atmel
Описание: Микроконтроллеры (MCU) MRL А 64K Flash 16K SRAM Ind Temp
Features
· Core
ARM® Cortex®-M3 revision 2.0 running at up to 64 MHz Memory Protection Unit (MPU) Thumb®-2 instruction set Pin-to-pin compatible with AT91SAM7S legacy products (48- and 64-pin versions) Memories From 64 to 256 Kbytes embedded Flash, 128-bit wide access, memory accelerator, single plane From 16 to 48 Kbytes embedded SRAM 16 Kbytes ROM with embedded bootloader routines (UART, USB) and IAP routines 8-bit Static Memory Controller (SMC): SRAM, PSRAM, NOR and NAND Flash support Memory Protection Unit (MPU) System Embedded voltage regulator for single supply operation Power-on-Reset (POR), Brown-out Detector (BOD) and Watchdog for safe operation Quartz or ceramic resonator oscillators: 3 to 20 MHz main power with Failure Detection and optional low power 32.768 kHz for RTC or device clock High precision 8/12 MHz factory trimmed internal RC oscillator with 4 MHz default frequency for device startup.
In-application trimming access for frequency adjustment
- Серия процессора: ATSAM3x
- Ядро: ARM Cortex M3
- RoHS: да
ATSAM3S1BAAU, ATSAM3S1BA AU
