Клеммные колодки Keen Side
Datasheet ATSAM3S1CA-AU - Atmel Даташит Микроконтроллеры (MCU) MRL А 64K Flash 16K SRAM Ind Temp — Даташит
Наименование модели: ATSAM3S1CA-AU
Микросхема Микроконтроллер, MCU 32Bit SAM3S ARM Cortex M3 RISC 64KB Flash 1.8V/3.3V 100Pin LQFP
ATSAM3S1CA-AU
65 ₽
ATSAM3S1CA-AU
Atmel
639 ₽
ATSAM3S1CA-AU
Atmel
ATSAM3S1CA-AU
Atmel
Производитель: Atmel
Описание: Микроконтроллеры (MCU) MRL А 64K Flash 16K SRAM Ind Temp
data sheetСкачать Data Sheet
Features
· Core
­ ARM® Cortex®-M3 revision 2.0 running at up to 64 MHz ­ Memory Protection Unit (MPU) ­ Thumb®-2 instruction set Pin-to-pin compatible with AT91SAM7S legacy products (48- and 64-pin versions) Memories ­ From 64 to 256 Kbytes embedded Flash, 128-bit wide access, memory accelerator, single plane ­ From 16 to 48 Kbytes embedded SRAM ­ 16 Kbytes ROM with embedded bootloader routines (UART, USB) and IAP routines ­ 8-bit Static Memory Controller (SMC): SRAM, PSRAM, NOR and NAND Flash support ­ Memory Protection Unit (MPU) System ­ Embedded voltage regulator for single supply operation ­ Power-on-Reset (POR), Brown-out Detector (BOD) and Watchdog for safe operation ­ Quartz or ceramic resonator oscillators: 3 to 20 MHz main power with Failure Detection and optional low power 32.768 kHz for RTC or device clock ­ High precision 8/12 MHz factory trimmed internal RC oscillator with 4 MHz default frequency for device startup.
In-application trimming access for frequency adjustment
  • Серия процессора: ATSAM3x Factory Pack Quantity:90
  • Ядро: ARM Cortex M3
  • RoHS: да
ATSAM3S1CAAU, ATSAM3S1CA AU
На английском языке: Datasheet ATSAM3S1CA-AU - Atmel Microcontrollers (MCU) MRL A 64K Flash 16K SRAM Ind Temp
