Datasheet ATSAM3S4AA-AU - Atmel Даташит Микроконтроллеры (MCU) MRL А 256K Flash 48K SRAM Ind Temp — Даташит
Наименование модели: ATSAM3S4AA-AU
![]() 28 предложений от 19 поставщиков Микросхема Микроконтроллер, RISC Microcontroller, 32Bit, FLASH, CORTEX-M3 CPU, 64MHz, CMOS, PQFP48, 7 X 7MM, 0.5MM PITCH, GREEN, MS-026, LQFP-48 | |||
ATSAM3S4AA-AU Microchip | от 945 ₽ | ||
ATSAM3S4AA-AU Microchip | от 996 ₽ | ||
ATSAM3S4AA-AU Atmel | по запросу | ||
ATSAM3S4AA-AU Microchip | по запросу |
Производитель: Atmel
Описание: Микроконтроллеры (MCU) MRL А 256K Flash 48K SRAM Ind Temp
Features
· Core
ARM® Cortex®-M3 revision 2.0 running at up to 64 MHz Memory Protection Unit (MPU) Thumb®-2 instruction set Pin-to-pin compatible with AT91SAM7S legacy products (48- and 64-pin versions) Memories From 64 to 256 Kbytes embedded Flash, 128-bit wide access, memory accelerator, single plane From 16 to 48 Kbytes embedded SRAM 16 Kbytes ROM with embedded bootloader routines (UART, USB) and IAP routines 8-bit Static Memory Controller (SMC): SRAM, PSRAM, NOR and NAND Flash support Memory Protection Unit (MPU) System Embedded voltage regulator for single supply operation Power-on-Reset (POR), Brown-out Detector (BOD) and Watchdog for safe operation Quartz or ceramic resonator oscillators: 3 to 20 MHz main power with Failure Detection and optional low power 32.768 kHz for RTC or device clock High precision 8/12 MHz factory trimmed internal RC oscillator with 4 MHz default frequency for device startup.
In-application trimming access for frequency adjustment
- Серия процессора: ATSAM3x Factory Pack Quantity:250
- Ядро: ARM Cortex M3
- RoHS: да
ATSAM3S4AAAU, ATSAM3S4AA AU
