Клеммные колодки Keen Side
Datasheet ATSAM3S4CA-AU - Atmel Даташит Микроконтроллеры (MCU) MRL А 256K Flash 48K SRAM Ind Temp — Даташит
Наименование модели: ATSAM3S4CA-AU
30 предложений от 20 поставщиков
Микросхема Микроконтроллер, RISC Microcontroller, 32Bit, FLASH, CORTEX-M3 CPU, 64MHz, CMOS, PQFP100, 14 X 14MM, 0.5MM PITCH, GREEN, MS-026, LQFP-100
IC Home
ATSAM3S4CA-AU
613 ₽
Эиком
ATSAM3S4CA-AU
от 1 105 ₽
ЗУМ-СМД
ATSAM3S4CA-AU
Atmel
Контест
ATSAM3S4CA-AU
Производитель: Atmel
Описание: Микроконтроллеры (MCU) MRL А 256K Flash 48K SRAM Ind Temp
data sheetСкачать Data Sheet
Features
· Core
­ ARM® Cortex®-M3 revision 2.0 running at up to 64 MHz ­ Memory Protection Unit (MPU) ­ Thumb®-2 instruction set Pin-to-pin compatible with AT91SAM7S legacy products (48- and 64-pin versions) Memories ­ From 64 to 256 Kbytes embedded Flash, 128-bit wide access, memory accelerator, single plane ­ From 16 to 48 Kbytes embedded SRAM ­ 16 Kbytes ROM with embedded bootloader routines (UART, USB) and IAP routines ­ 8-bit Static Memory Controller (SMC): SRAM, PSRAM, NOR and NAND Flash support ­ Memory Protection Unit (MPU) System ­ Embedded voltage regulator for single supply operation ­ Power-on-Reset (POR), Brown-out Detector (BOD) and Watchdog for safe operation ­ Quartz or ceramic resonator oscillators: 3 to 20 MHz main power with Failure Detection and optional low power 32.768 kHz for RTC or device clock ­ High precision 8/12 MHz factory trimmed internal RC oscillator with 4 MHz default frequency for device startup.
In-application trimming access for frequency adjustment
  • Серия процессора: ATSAM3x
  • Ядро: ARM Cortex M3
  • RoHS: да
ATSAM3S4CAAU, ATSAM3S4CA AU
На английском языке: Datasheet ATSAM3S4CA-AU - Atmel Microcontrollers (MCU) MRL A 256K Flash 48K SRAM Ind Temp
