Datasheet EFM32-G210-SK-F128 - Energy Micro Даташит Микроконтроллер, CORTEX-M3, EFM32-G210 SAMPLE-PK — Даташит
Наименование модели: EFM32-G210-SK-F128
6 предложений от 4 поставщиков Микроконтроллеры ARM 128KB FLASH 16KB RAM 32MHZ 1.8-3.8V | |||
EFM32G210F128 | от 483 ₽ | ||
EFM32G210F128 Silicon Labs | по запросу | ||
EFM32G210F128 | по запросу | ||
EFM32G210F128 Energy Micro | по запросу |
Производитель: Energy Micro
Описание: Микроконтроллер, CORTEX-M3, EFM32-G210 SAMPLE-PK
...the world's most energy friendly microcontrollers
EFM32G210 DATASHEET
EFM32G210F128
· ARM Cortex-M3 CPU platform · High Performance 32-bit processor @ up to 32 MHz · Memory Protection Unit · Wake-up Interrupt Controller · Flexible Energy Management System · 20 nA @ 3 V Shutoff Mode · 0.6 µA @ 3 V Stop Mode, including Power-on Reset, Brown-out Detector, RAM and CPU retention · 0.9 µA @ 3 V Deep Sleep Mode, including Real Time Clock with 32.768 kHz oscillator, Power-on Reset, Brown-out Detector, RAM and CPU retention · 45 µA/MHz @ 3 V Sleep Mode · 180 µA/MHz @ 3 V Run Mode, with code executed from flash · 128 KB Flash · 16 KB RAM · 24 General Purpose I/O pins · Configurable Push-pull, Open-drain, pull-up/down, input filter, drive strength · Configurable peripheral I/O locations · 14 asynchronous external interrupts · 8 Channel DMA Controller · 8 Channel Peripheral Reflex System for autonomous inter-peripheral signaling · Hardware AES with 128/256-bit keys in 54/75 cycles · Timers/Co
EFM32G210SKF128, EFM32 G210 SK F128
