Datasheet EFM32-G230-SK-F128 - Energy Micro Даташит Микроконтроллер, CORTEX-M3, EFM32-G230 SAMPLE-PK — Даташит
Energy Micro EFM32-G230-SK-F128
Наименование модели: EFM32-G230-SK-F128
EFM32-G230-SK-F128
Silicon Labs
1 163 ₽
Производитель: Energy Micro
Описание: Микроконтроллер, CORTEX-M3, EFM32-G230 SAMPLE-PK
data sheetСкачать Data Sheet
...the world's most energy friendly microcontrollers
EFM32G230 DATASHEET
F128/F64/F32
· ARM Cortex-M3 CPU platform · High Performance 32-bit processor @ up to 32 MHz · Memory Protection Unit · Wake-up Interrupt Controller · Flexible Energy Management System · 20 nA @ 3 V Shutoff Mode · 0.6 µA @ 3 V Stop Mode, including Power-on Reset, Brown-out Detector, RAM and CPU retention · 0.9 µA @ 3 V Deep Sleep Mode, including Real Time Clock with 32.768 kHz oscillator, Power-on Reset, Brown-out Detector, RAM and CPU retention · 45 µA/MHz @ 3 V Sleep Mode · 180 µA/MHz @ 3 V Run Mode, with code executed from flash · 128/64/32 KB Flash · 16/16/8 KB RAM · 56 General Purpose I/O pins · Configurable Push-pull, Open-drain, pull-up/down, input filter, drive strength · Configurable peripheral I/O locations · 16 asynchronous external interrupts · 8 Channel DMA Controller · 8 Channel Peripheral Reflex System for autonomous inter-peripheral signaling · Hardware AES with 128/256-bit keys in 54/75 cycles ·
EFM32G230SKF128, EFM32 G230 SK F128
На английском языке: Datasheet EFM32-G230-SK-F128 - Energy Micro MCU, CORTEX-M3, EFM32-G230 SAMPLE-PK
