Datasheet CY7C53120E2-10SXI - Cypress Даташит IC, 8 бит NETWORK PROCESSOR, 10 МГц QFP-64 — Даташит
Наименование модели: CY7C53120E2-10SXI
![]() 17 предложений от 14 поставщиков Микросхема Микроконтроллер, Network Processor, 10MHz, 8Bit, 12KB, 4.5V to 5.5V, QFP-64 | |||
CY7C53120E2-10SXI Cypress | 1 433 ₽ | ||
CY7C53120E2-10SXI Cypress | от 1 796 ₽ | ||
CY7C53120E2-10SXI Infineon | 10 027 ₽ | ||
CY7C53120E2-10SXI Cypress | по запросу |
Производитель: Cypress
Описание: IC, 8 бит NETWORK PROCESSOR, 10 МГц QFP-64
CY7C53150 CY7C53120
Neuron® Chip Network Processor
Features
· Three 8-bit pipelined processors for concurrent processing of application code and network traffic · 11-pin IO port programmable in 34 modes for fast application program development · Two 16-bit timer/counters for measuring and generating IO device waveforms · 5-pin communication port that supports direct connect and network transceiver interfaces · Programmable pull ups on IO4IO7 and 20 mA sink current on IO0IO3 · Unique 48-bit ID number in every device to facilitate network installation and management · Low operating current; sleep mode operation for reduced current consumption[1] · 0.35 m Flash process technology · 5.0V operation · On-chip LVD circuit to prevent nonvolatile memory corruption during voltage drops · 2,048 bytes of SRAM for buffering network data, system, and application data storage · 512 bytes (CY7C53150), 2048 bytes (CY7C53120E2), 4096 bytes (CY7C53120E4) of Flash memory with on-chip charge pump for fl
- Разрядность ядра: 8- бит
- Количество линий ввода/вывода: 11
- Память программ: 12 Кб
- Оперативная память: 2 Кб
- Тактовая частота: 10 МГц
- Тип генератора: внешний
- Количество таймеров: 2
- IC Case Style: QFP
CY7C53120E210SXI, CY7C53120E2 10SXI
