Datasheet TEALEAF-USB-DIL - HexWax Даташит ИС, PROG AUTHENTICATION, DIL28 — Даташит
HexWax TEALEAF-USB-DIL
Наименование модели: TEALEAF-USB-DIL
TEALEAF-USB-DIL65 ₽
TEALEAF-USB-DILпо запросу
Производитель: HexWax
Описание: ИС, PROG AUTHENTICATION, DIL28
data sheetСкачать Data Sheet
TEAleaf-USB
Summary
TEAleaf-USB is a low cost authentication system which may be used to verify that a software product is not an unauthorized pirate copy.
The host PC uses a simple but robust algorithm to verify that a TEAleaf-USB device is present, using a 128-bit encryption key. A complete set of BOM and Gerber blueprints is available off-the-shelf manufacture of ultra low cost TEAleaf-USB hardware security keys. TEAleaf-USB uses the Human Interface Device (HID) USB profile. It does not require USB drivers and is immediately plug-and-play compatible with present and future Windows, Linux and Mac operating systems. TEAleaf-USB is available in 28-pin DIL and 20-pin SSOP packages. They require only a few discrete components.
TM
USB Authentication Key for Software Licensing and Revenue Protection
  • Разрядность ядра: 8 бит
  • Количество линий ввода/вывода: 5
  • Тип корпуса: DIP
  • Диапазон напряжения питания: 3.3 В ... 5.5 В
  • Количество выводов: 28
  • Интерфейс: I2C, SPI, USB
Дополнительные аксессуары:
  • Panasonic - EYGA091203SM
  • Panasonic - EYGA121807A
TEALEAFUSBDIL, TEALEAF USB DIL
На английском языке: Datasheet TEALEAF-USB-DIL - HexWax IC, PROG AUTHENTICATION, DIL28
