Datasheet PIC18F25J50-I/ML - Microchip Даташит 8- бит микроконтроллеры (MCU) Full Spd USB 32 Кб Flsh 4KBRAM nanoWatt — Даташит
Наименование модели: PIC18F25J50-I/ML
Купить PIC18F25J50-I/ML на РадиоЛоцман.Цены — от 93 до 692 ₽29 предложений от 19 поставщиков IC MCU 8BIT 32KB FLASH 28QFN. PIC PIC® XLPTM 18J Microcontroller IC 8-Bit 48MHz 32KB (16K x 16) FLASH 28-QFN... | |||
| PIC18F25J50-I/ML Microchip | 219 ₽ | ||
| PIC18F25J50-I/ML Microchip | 323 ₽ | ||
| PIC18F25J50-I/ML Microchip | по запросу | ||
Производитель: Microchip
Описание: 8- бит микроконтроллеры (MCU) Full Spd USB 32 Кб Flsh 4KBRAM nanoWatt
PIC18F46J50 Family Data Sheet
28/44-Pin, Low-Power, High-Performance USB Microcontrollers with nanoWatt XLP Technology
© 2009 Microchip Technology Inc.
DS39931C
Note the following details of the code protection feature on Microchip devices: · · · Microchip products meet the specification contained in their particular Microchip Data Sheet.
Microchip believes that its family of products is one of the most secure families of its kind on the market today, when used in the intended manner and under normal conditions. There are dishonest and possibly illegal methods used to breach the code protection feature. All of these methods, to our knowledge, require using the Microchip products in a manner outside the operating specifications contained in Microchip's Data Sheets. Most likely, the person doing so is engaged in theft of intellectual property. Microchip is willing to work with the customer who is concerned about the integrity of their code. Neither Microchip nor any other semiconduct
- Supply Voltage - Max: 3.6 В
- Supply Voltage - Min: 2.15 В
- Вид монтажа: SMD/SMT
- Встроенный в чип АЦП: да
- Высота: 0.88 мм
- Длина: 6 мм
- Доступные аналоговые/цифровые каналы: 10
- Интерфейс: I2C, SPI, USART, USB
- Количество таймеров: 5
- Рабочее напряжение питания: 2.15 В ... 3.6 В
- Размер ОЗУ: 3776 B
- Разрядность АЦП: 10 бит
- Серия процессора: PIC18
- Тактовая частота максимальная: 48 МГц
- Тип корпуса: QFN EP
- Тип памяти программ: Flash
- Упаковка: Tube
- Шина данных: 8 бит
- Ширина: 6 мм
- Ядро: PIC18
- RoHS: да
PIC18F25J50I/ML, PIC18F25J50 I/ML
