Datasheet PIC18LF24J50-I/SO - Microchip Даташит 8- бит микроконтроллеры (MCU) Full Spd USB 16 Кб Flsh 4KBRAM nanoWatt — Даташит
Microchip PIC18LF24J50-I/SO
Наименование модели: PIC18LF24J50-I/SO
23 предложений от 15 поставщиков
IC MCU 8BIT 16KB FLASH 28SOIC. PIC PIC® XLPTM 18J Microcontroller IC 8-Bit 48MHz 16KB (8K x 16) FLASH 28-SOIC....
PIC18LF24J50-I/SO
140 ₽
PIC18LF24J50-I/SO
298 ₽
PIC18LF24J50-I/SO
от 542 ₽
Зенер
Россия и страны ТС
PIC18LF24J50-I/SO
от 583 ₽
Производитель: Microchip
Описание: 8- бит микроконтроллеры (MCU) Full Spd USB 16 Кб Flsh 4KBRAM nanoWatt
data sheetСкачать Data Sheet
PIC18F46J50 Family Data Sheet
28/44-Pin, Low-Power, High-Performance USB Microcontrollers with nanoWatt XLP Technology
© 2009 Microchip Technology Inc.
DS39931C
Note the following details of the code protection feature on Microchip devices: · · · Microchip products meet the specification contained in their particular Microchip Data Sheet.
Microchip believes that its family of products is one of the most secure families of its kind on the market today, when used in the intended manner and under normal conditions. There are dishonest and possibly illegal methods used to breach the code protection feature. All of these methods, to our knowledge, require using the Microchip products in a manner outside the operating specifications contained in Microchip's Data Sheets. Most likely, the person doing so is engaged in theft of intellectual property. Microchip is willing to work with the customer who is concerned about the integrity of their code. Neither Microchip nor any other semiconduct
  • Supply Voltage - Max: 2.75 В, 3.6 В
  • Supply Voltage - Min: 2 В
  • Вид монтажа: SMD/SMT
  • Встроенный в чип АЦП: да
  • Высота: 2.31 мм
  • Длина: 17.87 мм
  • Доступные аналоговые/цифровые каналы: 10
  • Интерфейс: EUSART, I2C, SPI
  • Количество линий ввода/вывода: 16
  • Количество таймеров: 5
  • Рабочее напряжение питания: 2 В ... 3.6 В
  • Рабочий диапазон температрур: - 40 C ... + 125 C
  • Размер ОЗУ: 16 Кб
  • Размер памяти программ: 16 Кб
  • Разрядность АЦП: 10 бит
  • Серия процессора: PIC18
  • Тактовая частота максимальная: 31 кГц
  • Тип корпуса: SOIC-28
  • Тип памяти программ: Flash
  • Упаковка: Tube
  • Шина данных: 8 бит
  • Ширина: 7.49 мм
  • Ядро: PIC
  • RoHS: да
PIC18LF24J50I/SO, PIC18LF24J50 I/SO
На английском языке: Datasheet PIC18LF24J50-I/SO - Microchip 8- bit Microcontrollers (MCU) Full Spd USB 16 Kb Flsh 4KBRAM nanoWatt
