Datasheet PIC18LF25J11-I/ML - Microchip Даташит 8- бит микроконтроллеры (MCU) 32 Кб Flash 4KBRAM 12MIPS nanoWatt — Даташит
Наименование модели: PIC18LF25J11-I/ML
Купить PIC18LF25J11-I/ML на РадиоЛоцман.Цены — от 81 до 1 554 ₽15 предложений от 15 поставщиков IC MCU 8BIT 32KB FLASH 28QFN. PIC PIC® XLPTM 18J Microcontroller IC 8-Bit 48MHz 32KB (16K x 16) FLASH 28-QFN... | |||
| PIC18LF25J11-I/ML Microchip | 81 ₽ | ||
| PIC18LF25J11-I/ML Microchip | 216 ₽ | ||
| PIC18LF25J11-I/ML | 237 ₽ | ||
| PIC18LF25J11-I/ML Microchip | по запросу | ||
Производитель: Microchip
Описание: 8- бит микроконтроллеры (MCU) 32 Кб Flash 4KBRAM 12MIPS nanoWatt
PIC18F46J11 Family Data Sheet
28/44-Pin, Low-Power, High-Performance Microcontrollers with nanoWatt XLP Technology
© 2009 Microchip Technology Inc.
DS39932C
Note the following details of the code protection feature on Microchip devices: · · · Microchip products meet the specification contained in their particular Microchip Data Sheet.
Microchip believes that its family of products is one of the most secure families of its kind on the market today, when used in the intended manner and under normal conditions. There are dishonest and possibly illegal methods used to breach the code protection feature. All of these methods, to our knowledge, require using the Microchip products in a manner outside the operating specifications contained in Microchip's Data Sheets. Most likely, the person doing so is engaged in theft of intellectual property. Microchip is willing to work with the customer who is concerned about the integrity of their code. Neither Microchip nor any other semiconductor m
- Supply Voltage - Max: 2.75 В, 3.6 В
- Supply Voltage - Min: 2 В
- Вид монтажа: SMD/SMT
- Встроенный в чип АЦП: да
- Высота: 0.88 мм
- Длина: 6 мм
- Доступные аналоговые/цифровые каналы: 10
- Интерфейс: EUSART, I2C, SPI
- Количество линий ввода/вывода: 16
- Количество таймеров: 5
- Рабочее напряжение питания: 2 В ... 3.6 В
- Рабочий диапазон температрур: - 40 C ... + 125 C
- Размер ОЗУ: 4 Кб
- Разрядность АЦП: 10 бит
- Серия процессора: PIC18
- Тактовая частота максимальная: 31 кГц
- Тип корпуса: QFN-28
- Тип памяти программ: Flash
- Упаковка: Tube
- Шина данных: 8 бит
- Ширина: 6 мм
- Ядро: PIC
- RoHS: да
PIC18LF25J11I/ML, PIC18LF25J11 I/ML
