Datasheet PIC18F25K20-E/SP - Microchip Даташит 8- бит микроконтроллеры (MCU) 32 Кб Flash 1536B RAM 25 I/O 8B — Даташит
Microchip PIC18F25K20-E/SP
Наименование модели: PIC18F25K20-E/SP
28 предложений от 18 поставщиков
Микросхема Микроконтроллер 8, MICROCHIP PIC18F25K20-E/SP 8Bit Microcontroller, Flash, PIC18FxxKxx, 64MHz, 32KB, 1.5KB, 28Pins, DIP
PIC18F25K20-E/SP
192 ₽
PIC18F25K20-E/SP
233 ₽
PIC18F25K20-E/SP
255 ₽
Hi-Tech Circuit Group
PIC18F25K20-E/SP
Производитель: Microchip
Описание: 8- бит микроконтроллеры (MCU) 32 Кб Flash 1536B RAM 25 I/O 8B
data sheetСкачать Data Sheet
PIC18F23K20/24K20/25K20/26K20/ 43K20/44K20/45K20/46K20 Data Sheet
28/40/44-Pin Flash Microcontrollers with nanoWatt XLP Technology
2010 Microchip Technology Inc.
DS41303G
Note the following details of the code protection feature on Microchip devices: · · Microchip products meet the specification contained in their particular Microchip Data Sheet.
Microchip believes that its family of products is one of the most secure families of its kind on the market today, when used in the intended manner and under normal conditions. There are dishonest and possibly illegal methods used to breach the code protection feature. All of these methods, to our knowledge, require using the Microchip products in a manner outside the operating specifications contained in Microchip's Data Sheets. Most likely, the person doing so is engaged in theft of intellectual property. Microchip is willing to work with the customer who is concerned about the integrity of their code. Neither Microchip nor any other se
  • Supply Voltage - Max: 3.6 В
  • Supply Voltage - Min: 1.8 В
  • Вид монтажа: Through Hole
  • Встроенный в чип АЦП: да
  • Высота: 3.3 мм
  • Длина: 34.67 мм
  • Доступные аналоговые/цифровые каналы: 11
  • Интерфейс: CCP, ECCP, EUSART, I2C, MSSP, SPI
  • Количество линий ввода/вывода: 25
  • Количество таймеров: 4
  • Рабочее напряжение питания: 1.8 В ... 3.6 В
  • Рабочий диапазон температрур: - 40 C ... + 125 C
  • Размер ОЗУ: 1.5 Кб
  • Размер памяти программ: 32 Кб
  • Разрядность АЦП: 10 бит
  • Серия процессора: PIC18
  • Тактовая частота максимальная: 64 МГц
  • Тип корпуса: SPDIP
  • Тип памяти программ: Flash
  • Упаковка: Tube
  • Шина данных: 8 бит
  • Ширина: 7.24 мм
  • Ядро: PIC
  • RoHS: да
PIC18F25K20E/SP, PIC18F25K20 E/SP
На английском языке: Datasheet PIC18F25K20-E/SP - Microchip 8- bit Microcontrollers (MCU) 32 Kb Flash 1536B RAM 25 I/O 8B
