Datasheet LPC2105BBD48.151 - NXP Даташит 32 бит микроконтроллер 128K FLASH, SMD, 2105 — Даташит
Наименование модели: LPC2105BBD48.151
13 предложений от 13 поставщиков IC MCU 32BIT 128KB FLASH 48LQFP. ARM7® LPC2100 Microcontroller IC 16/32-Bit 60MHz 128KB (128K x 8) FLASH 48-LQFP (7x7). Embedded -... | |||
| LPC2105BBD48,151 NXP | по запросу | ||
Производитель: NXP
Описание: 32 бит микроконтроллер 128K FLASH, SMD, 2105
LPC2104/2105/2106
Single-chip 32-bit microcontrollers; 128 kB ISP/IAP Flash with 64 kB/32 kB/16 kB RAM
Rev.
04 -- 05 February 2004 Product data
1. General description
The LPC2104, 2105 and 2106 are based on a 16/32 bit ARM7TDMI-S CPU with real-time emulation and embedded trace support, together with 128 kbytes (kB) of embedded high speed flash memory. A 128 bit wide memory interface and a unique accelerator architecture enable 32 bit code execution at maximum clock rate. For critical code size applications, the alternative 16-bit Thumb Mode reduces code by more than 30% with minimal performance penalty. Due to their tiny size and low power consumption, these microcontrollers are ideal for applications where miniaturization is a key requirement, such as access control and point-of-sale. With a wide range of serial communications interfaces and on-chip SRAM options up to 64 kilobytes, they are very well suited for communication gateways and protocol converters, soft modems, voice recogn
- Размер ОЗУ: 32 Кб
- Количество таймеров: 4
- Тип корпуса: LQFP
- Рабочий диапазон температрур: 0°C ... +70°C
- Количество выводов: 48
- SVHC: No SVHC (18-Jun-2010)
- Семейство: LPC2105
- Тактовая частота: 60 МГц
- IC Generic Number: 2105
- Количество логических функций: 2105
- Размер памяти: 128 Кб
- Тип памяти: Flash
- Особые функции: 16/32 бит ARM7TDMI-S processor, 16/32/64 Кб on-chip Static RAM, 128 Кб on-chip Flash Program Memory, In-System Programming (ISP) and In-Application Programming (IAP), Vectored Interrupt Controller, EmbeddedICE-RT interface, Embedded Trace Macrocell
- Количество битов: 32
- Количество линий ввода/вывода: 32
- Разрядность таймера: 32
- Тип генератора: On-chip crystal
- Количество COM портов: IВІC, SPI, 2x UART
- Способ монтажа: SMD
- Voltage Vcc: 3.6 В
Дополнительные аксессуары:
- Dataman - DATAMAN 848PRO
