Datasheet LPC2134FBD64,151 - NXP Даташит ИС, 16/32 бит микроконтроллер ARM7, SMD, LPC2134 — Даташит
NXP LPC2134FBD64,151
Наименование модели: LPC2134FBD64,151
15 предложений от 15 поставщиков
IC MCU 32BIT 128KB FLASH 64LQFP. ARM7® LPC2100 Microcontroller IC 16/32-Bit 60MHz 128KB (128K x 8) FLASH 64-LQFP (10x10). Embedded -...
LPC2134FBD64.151
888 ₽
LPC2134FBD64,151
Hi-Tech Circuit Group
LPC2134FBD64,151
LPC2134FBD64,151
Производитель: NXP
Описание: ИС, 16/32 бит микроконтроллер ARM7, SMD, LPC2134
data sheetСкачать Data Sheet
LPC2131/32/34/36/38
Single-chip 16/32-bit microcontrollers; 32/64/128/256/512 kB ISP/IAP flash with 10-bit ADC and DAC
Rev.
04 -- 16 October 2007 Product data sheet
1. General description
The LPC2131/32/34/36/38 microcontrollers are based on a 16/32-bit ARM7TDMI-S CPU with real-time emulation and embedded trace support, that combine the microcontroller with 32 kB, 64 kB, 128 kB, 256 kB and 512 kB of embedded high-speed flash memory. A 128-bit wide memory interface and a unique accelerator architecture enable 32-bit code execution at maximum clock rate. For critical code size applications, the alternative 16-bit Thumb mode reduces code by more than 30 % with minimal performance penalty. Due to their tiny size and low power consumption, these microcontrollers are ideal for applications where miniaturization is a key requirement, such as access control and point-of-sale. With a wide range of serial communications interfaces and on-chip SRAM options of 8 kB, 16 kB, and 32 kB, they are ver
  • Семейство: LPC2
  • Размер ОЗУ: 16 Кб
  • Количество таймеров: 4
  • Количество каналов ШИМ: 6
  • Тип корпуса: LQFP
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Количество выводов: 64
  • Тактовая частота: 60 МГц
  • Размер памяти Flash: 128 Кб
  • IC Generic Number: LPC2134
  • Интерфейс: I2C, SPI, UART
  • Размер памяти: 128K
  • Тип памяти: FLASH
  • Особые функции: 16 Кб on-chip Static RAM, Two 32- бит timers (with four capture and four compare channels), ШИМ unit (six outputs), Real Time Clock and Watchdog, On-chip crystal oscillator, Two low power modes, Idle and Power-down, 128/256 Кб on-chip Flash Program Memory, 128- бит wide interface/accelerator
  • Количество входов АЦП: 16
  • Количество битов: 16 / 32
  • Количество внешних прерываний: 4
  • Количество линий ввода/вывода: 47
  • Разрядность таймера: 32
  • Количество COM портов: 2xUART, 2xI2C, 2xSPI
  • Способ монтажа: SMD
  • Диапазон напряжения питания: 3 В ... 3.6 В
Дополнительные аксессуары:
  • IQD FREQUENCY PRODUCTS - LF A158K
  • Roth Elektronik - RE471
LPC2134FBD64151, LPC2134FBD64 151
На английском языке: Datasheet LPC2134FBD64,151 - NXP IC, 16/32 bit MCU ARM7, SMD, LPC2134
