Datasheet LPC2119FBD64,151 - NXP Даташит ИС, 16/32 бит микроконтроллер ARM7, SMD, LPC2119 — Даташит
NXP LPC2119FBD64,151
Наименование модели: LPC2119FBD64,151
7 предложений от 7 поставщиков
Микроконтроллеры ARM ARM7/128K FL/CAN/ADC
LPC2119FBD64,151
LPC2119FBD64,151
LPC2119FBD64151PBF
LPC2119FBD64.151PBF
Производитель: NXP
Описание: ИС, 16/32 бит микроконтроллер ARM7, SMD, LPC2119
data sheetСкачать Data Sheet
LPC2109/2119/2129
Single-chip 16/32-bit microcontrollers; 64/128/256 kB ISP/IAP flash with 10-bit ADC and CAN
Rev.
06 -- 10 December 2007 Product data sheet
1. General description
The LPC2109/2119/2129 are based on a 16/32-bit ARM7TDMI-S CPU with real-time emulation and embedded trace support, together with 64/128/256 kB of embedded high-speed flash memory. A 128-bit wide memory interface and a unique accelerator architecture enable 32-bit code execution at maximum clock rate. For critical code size applications, the alternative 16-bit Thumb mode reduces code by more than 30 % with minimal performance penalty. With their compact 64-pin package, low power consumption, various 32-bit timers, 4-channel 10-bit ADC, two advanced CAN channels, PWM channels and 46 fast GPIO lines with up to nine external interrupt pins these microcontrollers are particularly suitable for automotive and industrial control applications, as well as medical systems and fault-tolerant maintenance buses. With a wi
  • Семейство: LPC2
  • Размер ОЗУ: 16 Кб
  • Количество таймеров: 4
  • Количество каналов ШИМ: 6
  • Тип корпуса: LQFP
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Количество выводов: 64
  • Тактовая частота: 60 МГц
  • Размер памяти Flash: 128 Кб
  • IC Generic Number: LPC2119
  • Интерфейс: CAN, I2C, SPI, UART
  • Размер памяти: 128K
  • Тип памяти: FLASH
  • Особые функции: 16 Кб on-chip Static RAM, Two 32- бит timers (with four capture and four compare channels), ШИМ unit (six outputs), Real Time Clock and Watchdog, On-chip crystal oscillator, Two low power modes, Idle and Power-down, 128 Кб on-chip Flash Program Memory, 128- бит wide interface/accelerator
  • Количество входов АЦП: 4
  • Количество битов: 16 / 32
  • Количество внешних прерываний: 3
  • Количество линий ввода/вывода: 46
  • Разрядность таймера: 32
  • Количество COM портов: 2xUART, I2C, 2xSPI, 2xCAN
  • Способ монтажа: SMD
  • Диапазон напряжения питания: 3 В ... 3.6 В
Дополнительные аксессуары:
  • IQD FREQUENCY PRODUCTS - LF A158K
  • IQD FREQUENCY PRODUCTS - LF A161K
  • Roth Elektronik - RE471
LPC2119FBD64151, LPC2119FBD64 151
На английском языке: Datasheet LPC2119FBD64,151 - NXP IC, 16/32 bit MCU ARM7, SMD, LPC2119
