Datasheet Texas Instruments TMS470R1A384PGET — Даташит
| Серия | TMS470R1A384 |
| Модель | TMS470R1A384PGET |
16/32-битный RISC-флэш-микроконтроллер 144-LQFP
TMS470R1A384 16/32-Bit RISC Flash Microcontroller datasheet
PDF, 629 Кб, Версия: E, Файл опубликован: 21 май 2008
|  Купить TMS470R1A384PGET на РадиоЛоцман.Цены — от 472 до 4 386 ₽ 14 предложений от 14 поставщиков IC MCU 32BIT 384KB FLASH 144LQFP. ARM7® TMS470 Microcontroller IC 16/32-Bit 48MHz 384KB (384K x 8) FLASH 144-LQFP (20x20). Embedded -... | |||
| TMS470R1A384PGET Texas Instruments | 472 ₽ | ||
| TMS470R1A384PGET Texas Instruments | по запросу | ||
| Статус продукта | NRND (Не рекомендуется для новых разработок) |
| Pin | 144 | 144 |
| Package Type | PGE | PGE |
| Industry STD Term | LQFP | LQFP |
| JEDEC Code | S-PQFP-G | S-PQFP-G |
| Package QTY | 60 | 60 |
| Carrier | JEDEC TRAY (10+1) | JEDEC TRAY (10+1) |
| Маркировка | 470R1A384PGET | TMS |
| Width (мм) | 20 | 20 |
| Length (мм) | 20 | 20 |
| Thickness (мм) | 1.4 | 1.4 |
| Pitch (мм) | .5 | .5 |
| Max Height (мм) | 1.6 | 1.6 |
- Important ARM Ltd Application Notes for TI Hercules ARM Safety MCUsPDF, 61 Кб, Файл опубликован: 17 ноя 2011
 The purpose of this application report is to offer a convenient collection of references to application notes posted by ARM Ltd that apply to TI’s Hercules ARM Safety Microcontrollers. The document contains links directly to the ARM documents in the ARM On-Line InfoCenter as well as re-prints the ARM introduction chapter to help you better determine if you want to investigate further.
- 3.3 V I/O Considerations for Hercules Safety MCUs (Rev. A)PDF, 103 Кб, Версия: A, Файл опубликован: 6 сен 2011
 As new generations of microcontrollers lower their supply voltages from 5 V to 3.3 V and beyond, issues with interfacing and noise are increasing. This application report presents cost-effective interfacing techniques for inputs and outputs of 3.3 V microprocessors in an automotive environment. In addition, concerns about 3.3 V analog-to-digital converters (ADC) are discussed.
Серия: TMS470R1A384 (4)
- TMS470R1A384PGEQ TMS470R1A384PGET TMS470R1A384PZ-T TMS470R1A384PZQ
- Semiconductors > Microcontrollers (MCU) > Other Microcontrollers > TMS470 ARM7TDMI®-Based Industrial MCUs
